Advice on the numerical solution of the 1D Navier-Stokes equations
Old   May 4, 2016, 15:30
Default Advice on the numerical solution of the 1D Navier-Stokes equations
Daniel Potter
Deiniol is on a distinguished road
Hi all, the last few days I have been reading up on numerical methods, I was hoping to write a MATLAB code to solve the 1D Navier-Stokes equations for a uniform rectangular channel of depth h and width b:
\frac{\partial\hat{u}}{\partial t}-\hat{u}\frac{\partial\hat{u}}{\partial x}=-g\frac{\partial\eta}{\partial x}-\frac{1}{h+\eta}c_f\hat{u}|\hat{u}|
(momentum) and:
\frac{\partial\eta}{\partial t}+h\frac{\partial\hat{u}}{\partial x}+\frac{\partial(\eta\hat{u})}{\partial x} = 0
(continuity). where \hat{u} is the cross-sectionally averaged flow velocity and \eta is the water surface elevation. The only forcing I am interested in is that of the tide.
I would appreciate any pointers on how two go about solving these equations, from what I have read so far I am thinking of using the finite difference method, on a staggered grid, but with the coupling and the non-linear terms I am finding it tough going. If anyone would be able to point me in the right direction for any code or worked examples for analogous cases I would be very grateful, or even a good book with worked examples and code (MATLAB/FORTRAN/python) for CFD in general would be helpful.
Thanks in advance and I hope this is the correct forum for this post.
Deiniol is offline   Reply With Quote
Old   May 4, 2016, 15:44
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
(momentum) and:
You are not solving the NS equations.... however, for your problem you can see the book of Leveque and the problems here
http://www.clawpack.org/galleries.html
FMDenaro is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Exact solution - Euler equations jakubstary Main CFD Forum 9 May 6, 2013 18:14
Navier Stokes Equations on Grad School Statement of Purpose pyroknife Main CFD Forum 0 January 22, 2013 14:15
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
Navier stokes and the standard Galerkin method micheldup Main CFD Forum 0 March 1, 2011 09:24
