May 20, 2015, 13:51 |
Simulation of moving normal shock wave
ROHAN
Rep Power: 12 |
In a test case, there is a normal shock moving inside a domain(piston say) where there are two fluids with a well defined interface. This shock moves and interacts with the interface leading to a new fluid structure. I am not able to code for this moving shock wave, I've only worked with stationary shocks. Any advise would be much appreciated. This is actually the Richtmyer-Meshkov instability case. thanks |
May 22, 2016, 03:14 |
shock tube
cfduser
Rep Power: 9 |
+ROHAN : shock tube might solve your problem... you can visit this post
"Shock tube simulation in Fluent ...... http://www.cfd-online.com/Forums/fluent/73300-shock-tube-simulation-fluent.html" |
shock, simulation |
detonation wave simulation | Krish | FLUENT | 15 | February 7, 2017 12:38 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 03:16 |
Shock tube simulation | harish | FLUENT | 5 | January 25, 2014 02:20 |
[ask] shock absorber simulation | dik | Main CFD Forum | 1 | December 17, 2009 01:32 |
Will compression waves overtake a moving shock? | GRA | Main CFD Forum | 2 | October 19, 2006 00:24 |
