test cases for 1D inviscid incompressible flow |
May 27, 2016, 03:45 |
LUQILIN
Rep Power: 9 |
Hello, guys
I have always been focusing on compressible flow. However, I would like to solve some incompressible problems. I prefer somebody could send me 1D test cases governing by Euler equations. The test case had better be a benchmark problem with exact solution. I would be grateful if anyone could share his wisdom and experiences. Best Regards, |
May 27, 2016, 04:02 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
May 27, 2016, 04:11 |
LUQILIN
Rep Power: 9 |
Thank you for reply.
Maybe I did not express myself clear. I want to solve incompressible flow with artificial compressibility. So a pseudo time will be added into the mass conservation law. I just want to ignore viscous terms first. Maybe there remains some problems. |
May 27, 2016, 04:19 |
#4 | |
Rep Power: 71 |
d rho/dt + d(rho*u)/dx=0 how do you enforce the "incompressible" constraint? |
May 27, 2016, 04:38 |
#5 | |
LUQILIN
Rep Power: 9 |
Say d rho*/d t*, and t* is a pseudo time, rho* is a pseudo time. p= beta×rho*, p is pressure and beta is a parameter to be determined. We can apply time-marching strategy into incompressible flow problems with AC(artificial compressibility). See in: Chorin, Alexandre Joel. "A numerical method for solving incompressible viscous flow problems." Journal of computational physics 2.1 (1967): 12-26. The first paper for AC. Hope I express myself clear this time. |
May 27, 2016, 05:09 |
Rep Power: 71 |
but at a physical steady state with rho=constant you simply get du/dx= 0...
therefore your solution is a constant state for the velocity...It can only vary with time according to du/dt + dp/dx=0. But dp/dx is rho dependent.. |
May 27, 2016, 05:11 |
#7 | |
Rep Power: 71 |
The paper of Chorin is for a 2D flow... |
May 27, 2016, 05:20 |
LUQILIN
Rep Power: 9 |
--Yeah, the velocity should be constant at steady state. It seems the case is too simple, i should take viscous term account at least.
--I intend to combine AC with high order method for time-marching problem. I don't know whether this way can work, so I want to begin the simple case: 1D. What is your suggestion? |
May 27, 2016, 05:24 |
#9 | |
Rep Power: 71 |
even with viscous term in 1D you get u= constant ... the simplest 1D model is the Burgers equation in which du/dx does not vanish (therefore is a compressible model)... otherwise you must solve a 2D problem enforcing Div v =0 |
May 27, 2016, 05:27 |
#10 |
LUQILIN
Rep Power: 9 |
Ok. Thank your very much. I will try 2D.
May 27, 2016, 06:05 |
#11 |
LUQILIN
Rep Power: 9 |
And still, my original purpose is to ask for benchmark cases.
May 27, 2016, 07:54 |
#12 |
Rep Power: 71 |
Inviscid flow simulations in cfx | mahdidelfan | CFX | 1 | June 29, 2014 06:14 |
Drag in inviscid flow | jinny | Main CFD Forum | 6 | June 1, 2014 23:59 |
What solver to use for inviscid flow simulation over missile | mecbe2002 | OpenFOAM | 0 | April 27, 2010 11:10 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 17:49 |
