Simulating Ejector with two inlets
Old   March 2, 2016, 06:04
Default Simulating Ejector with two inlets
Pradeep Gupta
10ume039 is on a distinguished road
Dear Friends,
I have to simulate an Ejector having two inlets. One from boiler (high pressure high temperature refrigerant) and other if from evaporator (Low pressure low temperature refrigerant).
Can anybody suggest me which type of boundary condition I can take?
I have taken velocity inlet. Defined both the pressure and temperature but the problem is that when I plotting the contour of pressure and temperature I found that the both inlet are at maximum pressure and minimum temperature while in boundary condition I have given temperature and pressure at both inlets.
Pls anybody tell me why its happening?
10ume039 is offline   Reply With Quote
Old   March 15, 2016, 02:28
Bashir
bashirelhub is on a distinguished road
I think it is better to choose the pressure as boundary conditions
bashirelhub is offline   Reply With Quote
Old   March 15, 2016, 02:29
Bashir
It is my suggestion to use the pressure as i found in the manual of fluent
Old   May 26, 2016, 02:37
Luke
aerospace84 is on a distinguished road
i'm facing this kind of simulations actually, it works setting up pressure as boundaries,then you will compute the flow rates from the results
aerospace84 is offline   Reply With Quote
Mixture of the same fluid from 2 inlets godon Fluent UDF and Scheme Programming 0 October 15, 2012 08:04
Two pressure inlets problem Medison CFX 1 August 22, 2012 06:50
Is it possible to have multiple velocity inlets in your model boundarylayer FLUENT 0 June 5, 2010 02:29
Multiple Inlets Charlie V FLUENT 0 May 28, 2001 02:29
create Volume with inlets Roman Bohnes FLUENT 10 December 6, 1999 04:43
