CEL expression in CFX pre
Old   May 31, 2016, 08:36
Default CEL expression in CFX pre
meizhenwang
Jane92 is on a distinguished road
I am defining an expression of radial velocity under the cylindrical coordinate system in CFX pre. The expression is 0.3[m s^-1]*(y/(0.025[m]))^(1/7) .But when I run the CFX solver ,there is a error:
PROBLEM ENCOUNTERED WHEN EXECUTING CFX EXPRESSION LANGUAGE |
| The CFX expression language was evaluating: |
| Velocity r Component |
| The problem was: |
| INVALID-EXPONENTIATION |
| FURTHER INFORMATION |
| The problem was encountered in executing the expression for: |
| E1 |
| The complete expression is: |
| 0.3[m s^-1]*(y/(0.025[m]))^(1/7) |
| The error occurs on sub-expression: |
| BACKGROUND INFORMATION |
| The error was detected at one location. The same problem may be |
| present at other locations - that has not been investigated. |
| The following values are for the first location which has the |
| problem. |
| In this expression, these sub-expressions have been calculated: |
| Sub-expression = Value |
| 0.3[m s^-1] = 0.300000 |
| These values were set before reaching the current expression: |
| Name = Expression = Value |
| y = $LOCAL_y = -1.387779E-17 |
Jane92 is offline   Reply With Quote
Old   June 3, 2016, 02:48
david
davidwilcox is on a distinguished road
instead of using just "y", use "y+0.0001[m]".
davidwilcox is offline   Reply With Quote
CFX CEL expression for the Dyer boundary layer model equation mujahidbadshah CFX 0 April 21, 2016 10:21
Only two turbulence options available in CFX Pre Jack001 CFX 5 March 30, 2016 02:47
How to specify a polyline or plane in CFX Expression Language (CEL) in CFX-Pre? francis1 CFX 5 February 6, 2013 10:16
Conditional Expression in CFX Pre ashtonJ CFX 83 May 28, 2012 03:49
CFX Pre - TGrid Vivek Vasudevan CFX 2 March 20, 2007 06:31
