corrugated line periodic boundary conditions
Old   June 13, 2016, 10:11
Default corrugated line periodic boundary conditions
Andrew Brown
brownad6 is on a distinguished road
I am very new to Fluent and am trying to evaluate pressure drop through corrugated lines. I've heard there is a way to set a boundary conditions so that your geometry doesn't have to be so long. I think the idea is to let the outlet re-circulate to the inlet. The purpose here is to analyze the pressure drop through corrugated lines without having to create such a long section of pipe. Any advice will be greatly appreciated, thank you in advance.
Ansys Fluent V16.2
brownad6 is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
