momentum source with udf
Old   June 15, 2016, 23:55
Default momentum source with udf
Ahmet
firfilik is on a distinguished road
we have unit cell, lenght of it 3.66 m and we want to define momentum source at certain intervals with udf. How would I define it.
firfilik is offline   Reply With Quote
Old   June 16, 2016, 00:02
Michael Prinkey
mprinkey will become famous soon enough
You need to build DEFINE_SOURCEs for all three momentum components. The DEFINE_SOURCE will pass the cell and thread when it is called. You can use that to look up the cell centroid with C_CENTROID(X,cell,thread) where X is real X[ND_ND]. Then you can compute the momentum sources based on position information. It is a pretty textbook application of the DEFINE_SOURCE UDF mechanism.
mprinkey is offline   Reply With Quote
Old   June 16, 2016, 00:24
Ahmet
thank you Michael but I could not figure out how ı would place momentum source at 2 meters or 3 meters in udf
Old   June 16, 2016, 00:38
Michael Prinkey
Come on! You have the location vector for each cell as the DEFINE_SOURCE is called using the C_CENTROID macro. So, put in some tests to check if the cell is located near where you want the source and if so, set the source to the value you need. Otherwise, set it to zero.
DEFINE_SOURCE is one of the easiest UDFs to code. All of the parts on in the basic example in the ANSYS documentation.
https://www.sharcnet.ca/Software/Flu...udf/node46.htm
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
UDF for spatially dependent momentum source ngallandat3 Fluent UDF and Scheme Programming 14 July 27, 2014 12:21
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
