June 22, 2016, 04:42 |
initial particle concentration
Daixilei
Rep Power: 10 |
Hello, I want to simulate particle concentration decay in a room, and need to set a initial particle concentration for this room. Could you tell me how to do it, and which model is suitable for this problem.
June 24, 2016, 11:05 |
CHEN LONG
Rep Power: 12 |
you can use patch to initial the particle concentration
June 24, 2016, 11:31 |
Daixilei
Rep Power: 10 |
June 25, 2016, 08:06 |
Michael Prinkey
Rep Power: 25 |
If you are using DPM in Ansys FLUENT, the model doesn't (or at least, didn't used to) work that way. It was not a DEM-type solver where the particle locations and the fluid properties were integrated together in time. DPM (at least, used to) exist outside of the fluid solution loop and would do particle tracks through the fluid using the current velocity and temperature fields. The code did the bookkeeping to accumulate statistics that could then be feed back into the fluid flow as source terms. But all of the particle tracks (at least used to) need to terminate by hitting a wall with some adhesion rule, exiting through an outlet, or burning up completely.
So, based on initial particle distribution, I think you need to look to another model. If the particles are very small, you can use one of the simple multiphase eulerian models. If the particles are large and significantly effect the gas motion, you can either use a full DEM model (as in OpenFOAM or MFIX) or two-fluid eulerian model. |
June 25, 2016, 08:25 |
#5 | |
Daixilei
Rep Power: 10 |
June 25, 2016, 08:59 |
Michael Prinkey
Rep Power: 25 |
I honestly don't know. I left Ansys several versions ago. I am expert in Fluent 6.3 and earlier. I don't know of the current model compatibilities. But the multiphase models have been integrating more and more of the combustion capabilities. You will just have to read the documentation, talk to your Ansys support tech, or maybe try asking in the Fluent-specific forum here.
June 25, 2016, 09:47 |
#7 | |
Daixilei
Rep Power: 10 |
particle |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
