October 2, 2016, 13:30 |
deattached eddy simulation
zxc
Rep Power: 11 |
Hi
is there anybody who could help me to know what is DES method applications? also for an airfoil with high angle and seperation could it be used? Thanks |
October 2, 2016, 13:44 |
Filippo Maria Denaro
Rep Power: 71 |
I don't work using DES, but it was created to be somehow between RANS and LES for some applications with separated flow conditions.
You can give a look to this review: http://www.annualreviews.org/doi/abs....010908.165130 |
October 2, 2016, 15:02 |
zxc
Rep Power: 11 |
Thanks for your answer
but could you please tell that is it ok to use it for 2d problems? |
October 2, 2016, 15:12 |
#4 | |
Rep Power: 71 |
as you can see, the 2D problems was proposed at the end of the years '90 only as a preliminary exercise https://www.researchgate.net/profile...8919000000.pdf The mix with a LES field requires the 3D assumption. |
October 25, 2016, 02:06 |
Y+ value for DES model
vikrant
Rep Power: 11 |
Hello there,
I am doing free jet simulation using DES model. I am using this model for the first time. Can anyone please tell me the Y+ value guidelines for the simulation? |
Question about the Large eddy simulation (Fluent) | hamzaCFD | FLUENT | 2 | September 1, 2016 17:40 |
large eddy simulation | amin_veysi | OpenFOAM Pre-Processing | 2 | May 24, 2013 11:36 |
Large eddy simulation | jii1 | FLUENT | 0 | May 11, 2010 14:23 |
AHMED BODY (LARGE EDDY SIMULATION) | Benzamia | FLUENT | 0 | February 26, 2007 04:59 |
Large Eddy simulation | Andreas Hauser | Main CFD Forum | 1 | May 20, 2000 20:33 |
