Arbitrary Lagrangian Eulerian
Old   October 30, 2016, 08:11
Question Arbitrary Lagrangian Eulerian
Deep Sheth
cfdeep is on a distinguished road
Hello Everyone,
I am currently working on Fluid-Structure Interaction problems which needs me to use Arbitrary Lagrangian-Eulerian Meshing Techniques. I have been through a lot of literature and still haven't found any reliable source which can help me code it by myself. I need some algorithm for that matter (probably in 2 Dimensions). I have just joined CFD-Online and I don't have much experience here too. I would appreciate any codes made by anyone on which I can perform reverse engineering and understand it.
I need some source where I can learn ALE without much complicated equations as found in almost every open-source and literature.
Thank You in advance.
cfdeep is offline   Reply With Quote
Old   November 1, 2016, 00:21
Troy Snyder
tas38 is on a distinguished road
Originally Posted by cfdeep View Post
Hello Everyone,
Rather than reference literature that specifically uses the term "ALE description of motion", you may simply want to take a look at a fluid mechanics text which expresses the conservation equations of mass and momentum for moving control volumes. This is essentially the same thing as ALE (mesh/CVs can move independent of the fluid) but the presentation is more palatable. I recommend White's Introduction to Fluid Mechanics or Munson's Fundamentals of Fluid Mechanics.
tas38 is offline   Reply With Quote
ale, arbitrary, eulerian, lagrangian
converse lagrangian field to eulerian Jan_B OpenFOAM Programming & Development 0 August 13, 2015 13:11
Arbitrary lagrangian eulerian method in fluent saleh_1_2 FLUENT 0 June 29, 2014 23:42
Lagrangian, Eulerian and Lagrangian-Eulerian schemes freddyk Main CFD Forum 0 January 7, 2013 13:46
lagrangian vs eulerian approach leopoldo luongo CFX 1 June 19, 2006 10:12
Arbitrary Lagrangian Eulerian Methods Soheyl Main CFD Forum 1 June 12, 2006 03:42
