How to know your solution is correct? Circular cylinder
Old   September 27, 2017, 03:03
Default How to know your solution is correct? Circular cylinder
Marius Lang
Ursmooth is on a distinguished road
I am simulating a flow over a circular cylinder 2D Re=100, and I would like to know what do you need to check to know your solution is correct? I did a simulation with a course mesh (2300 elements) and a fine mesh (25 000 elements) and my results from drag and lift was not all that different (see picture, 600 timesteps is course mesh), and the Drag and Lift results from literature vary a bit aswell.
What do you need do you need to check to be sure you have a good result? Is there some kind of list of things you need to check? You clearly cant check only Drag and Lift.
In my fine mesh I have about 15 elements in my boundary layer and in my course mesh I have 1 element.
File Type: png Screen Shot 2017-09-27 at 08.46.50.png (108.2 KB, 11 views)
Ursmooth is offline   Reply With Quote
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Oscillating Cylinder in Parallel Flow: Analytical Solution startingcfd Main CFD Forum 7 March 23, 2012 05:49
[blockMesh] Grid generation cross flow over circular cylinder Yanma OpenFOAM Meshing & Mesh Conversion 0 July 7, 2010 08:02
base pressure for circular cylinder fpz Main CFD Forum 7 June 20, 2005 21:30
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
