Modeling leakage through surface asperities
Old   November 16, 2016, 17:54
Default Modeling leakage through surface asperities
Ahmed Jalal
A.Jalal is on a distinguished road
All,
I hope you are doing well. I was wondering if someone had ever simulated flow through surface asperities (gaps) that are a result of surface roughness. I know that these asperities are usually on the micro-level.
I am doing a project regarding leakage though metal-to-metal gaskets in API flanges to determine the leak rate in different surface properties.
Would like to start a discussion if anyone has previous experience with this type of simulations. I am indifferent to using either ANSYS Fluent 17 or Star CCM+ 11
Best regards,
A.Jalal is offline   Reply With Quote
Old   November 16, 2016, 18:06
Michael Prinkey
mprinkey will become famous soon enough
Originally Posted by A.Jalal View Post
All,
Best regards,
You might look at using the porous media models. You may be able to mesh a thin layer of porous media to represent the gap and use the roughness details to work out a porosity. If your layer is going to be very thin, make sure to use the double precision solvers.
Good luck.
mprinkey is offline   Reply With Quote
Old   November 30, 2016, 00:45
Ahmed Jalal
I was thinking more like generating a random 3D surface and attaching those node locations to the CAD model. Porous media would not take into account the surface roughness but that is a good way of modelling dynamic contacts.
gasket, leakage, leaking boundary, surface roughness
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 12:05
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
Modeling of free surface flow sam FLUENT 2 October 29, 2003 10:39
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 21:03
