December 20, 2016, 06:05 |
Free Surface Flows of Non-Newtonian Fluids
Aleck Alexopoulos
What are the best tools for this?
The problem is extrusion of a few cubic centimeters of hydrogel and attachment to a surface (time scale = 30-120seconds). Axi-symmetry assumption may be necessary. Surface tension forces would be nice but could be ignored initially. Non-Newtonian means fluid with elasticity not just shear dependent viscosity. A challenge indeed! |
December 20, 2016, 08:58 |
#2 | |
Arjun
Rep Power: 34 |
Extrusion is one of the application in my mind. |
December 22, 2016, 05:33 |
Extrusion < Attachment
Aleck Alexopoulos
The extrusion process is important but well analyzed in the literature (see 30year old work by Phan-Thien and Tanner with BEM). I have a lot of information there. The attachment process including adhesion, spreading, deformation and detachment from the extrusion needle are much less studied.
One approach is to assume axisymmetry and use a BEM formulation reducing the 3D problem to a 1D (also assuming negligible inertial terms). But the viscoelastic terms still need a volume grid to be determined. Small inertial effects could be also considered as a first order pertubation (using the same volume grid). Thoughts? |
dynamic, free surface flow, hydrogel, non-newtonian fluid |
CFX convergence issues with free surface | adenlan | CFX | 3 | September 2, 2011 06:43 |
High Reynolds Free Surface Flows | Ferreira | Main CFD Forum | 3 | September 28, 2005 02:45 |
CFX 4.4 New free surface option | Viatcheslav Anissimov | CFX | 0 | April 3, 2002 06:27 |
Free surface flows with solid transport | Patrice Jaumouillie | CFX | 3 | November 5, 2001 09:31 |
Modeling Free Surface Flows | Elliot Schwartz | Main CFD Forum | 5 | August 25, 1998 21:03 |
