How to know when a vortex shedding pattern has been onset? |
December 27, 2016, 17:57 |
Hector Redal
I would like to know how to measure / determine when a vortex karman shedding pattern has been established in an horizontal flow past a circular cylinder. What parameter is measured so as to determine when the vortex shedding has been onset? I was tryiing to simulate a flow past a circular cylinder with a horizontal velocity, and initially I was measuring the frequency of the vertical velocity. I assumed that when the frequency of this vertical velocity is greater than zero, the karman vortex shedding has been onset. But, after having read this reference, http://www.leb.eei.uni-erlangen.de/w...1/pdf/0116.pdf, I have some doubts about what really I was measuring. Maybe, the condition for the onset of the vortex shedding is not having frequency of the vertical velocity different than zero, but observing a repeating pattern of swirling vortices. Then, only by observation of the flow, this can be determine, can't it? Any reference I can take a look at is welcome / appreciated. Thanks. Best regards, Hector. |
December 27, 2016, 18:56 |
Filippo Maria Denaro
Rep Power: 71 |
You should determine not only a positive frequancy but a well determinated stationary frequency. That happens after the numerical transient, when the alternance of counterotating vortices is established.
December 28, 2016, 08:59 |
#3 | |
Hector Redal
I have uploaded several snapshots of the transient flow I am observing, ordered in increasing time step: from 1 (initial time step) to 5 (final time step). Is the pattern obserbed what is called a vortex shedding pattern? Best regards, Hector. |
December 28, 2016, 10:34 |
Alex
Rep Power: 47 |
I am not quite sure what you are trying to achieve. Are you interested in the time it takes until the onset of vortex shedding? Then you should have a much clearer definition for "onset of vortex shedding". Maybe the instant of time when a specific fraction of the final amplitude (vertical velocity, vertical force on cylinder...) is reached?
Edit: here are a few images from one of my tutorials. Heated cylinder, laminar, Re=200, Pr=1. The color represents the temperature, the lines are streamlines. 02.jpg symmetric flow field 03.jpg initial instability 05.jpg growing instability 06.jpg growing even further 07.jpg statistical steady-state |
January 5, 2017, 05:06 |
#5 | |
Hector Redal
When the Richardson number is zero, there are two counterrotating vortices in the rear part of the cylinder. As the richardson number increases, these two vortices should break and the vortex patter should appear. I would like to determine this Richardson number. I don't have such clear picture on when this happens. Does this happen when a periodic vertical velicity is observed in the right-most part of the domain (independently of the amplitud)? I mean, at the initial time, the velocity is horizontal at all points of the domain. As the simulation runs, a vertical velocity is observed at the point (x=L, y =H/2). This verticial velocity oscilates as the simulation runs, reaching a maximum value when the transient ends. Does a periodic value of the vertical velocity mean there are vortices in the flow? |
December 28, 2016, 10:37 |
Rep Power: 71 |
I suggest to plot the vorticity field and the vector field...the streamlines would help, too.
January 2, 2017, 16:47 |
Hector Redal
I have plot the streamlines of the flow that I am simulating. I have obtained them with Paraview program. I am not very familiar with it, so I am not obtained very much detailed and accurate pictures. Sorry for this. I can see a single vortex shedding from the rear part of the cylinder, and one single vortex close to the rear part of the cylinder. I assume that vortex sheeding is onset when two vortex are shed from the cylinder. Is my understanding correct? So based on this assumption, the vortex shedding has not still been set on. Right? Best regards, Hector. |
January 2, 2017, 17:16 |
Alex
Rep Power: 47 |
Is the undisturbed flow supposed to be a uniform velocity in x-direction?
I think you will need to tell us more about your simulation setup. Start with a detailed description of all boundary conditions. Continue with solver settings (and the type of solver you use), physical parameters/dimensionless numbers and include a few pictures of the mesh you used. |
January 2, 2017, 17:32 |
Rep Power: 71 |
I see a strange pattern ... the flow is not entering uniformly, it seems you have an angle... furthermore, the developing of the shedding seems still not complete.
1) how about the inflow velocity? 2) how about the time in your simulation? you should consider that a rough estimation of the non-dimensional time for the developed vortex shedding is of the order of the Re number. |
January 2, 2017, 17:47 |
#10 | |
Hector Redal
The Reynolds number of the simulation is 10. Richardson number 1.3 |
January 2, 2017, 17:52 |
#11 | |
Hector Redal
Is it because we can only see one single vortex shedding from the cylinder? |
January 2, 2017, 17:57 |
#12 | |
Rep Power: 71 |
without gravity, we know that the von Karman instability appears at Re=40-50. At Re=10 I expect two steady counterotating vortex. https://en.wikipedia.org/wiki/K%C3%A..._vortex_street |
January 2, 2017, 18:09 |
#13 | |
Hector Redal
Attached you can see the streamlines I am getting when no gravity at all (Re 20). At Re10, the two steady counterotating vortexes are smaller. The previous pictures were for the case where gravity is taken into account. |
January 2, 2017, 18:17 |
#14 | |
Rep Power: 71 |
January 5, 2017, 06:02 |
#15 | |
Hector Redal
It appears a good reference to take a look at. I will go through it and see if I can come to a conclusion. Thanks for your kind support, as always. |
January 5, 2017, 06:42 |
#16 |
Rep Power: 71 |
I think you should consider checking your code step-by-step.
First, be sure the temperature equation is well solve by running a case where it is just a passive scalar. You can check by menas of the iso-temperature curves. Then, active the gravity forcing (I think is directed along the y axis) for small Ri values. I would expect that the inflow velocity is not perturbed like I see in your previous figures. Of course, the literature you found is a further step to assess the code. |
January 2, 2017, 17:33 |
#17 |
Hector Redal
The undisturbed flow is a uniform velocity in the x-direction.
The force gravity is in the y direction. The cylinder is at a hotter temperature than the fluid with non-slip condition. The non-dimensional parameters are Re=10, Ri=1.3, Pr=0.72. Attached you can find a piture of the mesh I am using. |
January 2, 2017, 17:36 |
#18 | |
Rep Power: 71 |
Something is wrong with the inflow setting... there is not reason that the velocity vector has an angle along x.... I strongly suggest to run a case without force gravity and coupling with temperature to check if your code works fine. |
January 2, 2017, 17:50 |
#19 | |
Hector Redal
The velocity vector has an angle along the x direction when is near the cylinder. I think this is correct. Far away from the cylinder the velocity flow is horizontal. |
K-Epsilon for Vortex Shedding | Sham | FLUENT | 33 | March 29, 2017 05:48 |
No Vortex shedding for flow past cylinder | shashanktiwari619 | FLUENT | 7 | December 28, 2016 09:35 |
Flow Past a Cylinder, the Onset of Vortex Shedding | Nauseouslyquick | Main CFD Forum | 3 | October 23, 2016 16:46 |
Vortex shedding behind cylider in cross flow | Muthu | FLUENT | 0 | March 6, 2006 10:29 |
