Airfoil Experimental data - Low Re - Low Mach
Old   January 20, 2017, 10:12
Default Airfoil Experimental data - Low Re - Low Mach
William
Wingman is on a distinguished road
I'm trying to find some airfoil available with experimental data. I want to use my CFD model to simulate and compare with these results.
Preferably I would like some data used in similar condition as my project but I haven't found anything that immediately caught my attention.
Mach = 0.04 < 0.1
Velocity = ~ 15 m/s
Re = ~165.000
Chord L = ~0.165 m
Can any of you tell me where I could find such data?
Wingman is offline   Reply With Quote
Old   January 27, 2017, 09:20
Oliver Gloth
ogloth is on a distinguished road
take a look at this website:
http://m-selig.ae.illinois.edu/ads.html
There is a loads of airfoils and quite a few have links to experimental data or reports with testing data. Low speed testing data can also be found here:
http://m-selig.ae.illinois.edu/uiuc_lsat.html
Hope this helps!
Cheers,
Oliver
ogloth is offline   Reply With Quote
Comparison of experimental and CFD results for the VA-2 supercritical airfoil Aurélien FLUENT 3 April 24, 2024 10:39
Experimental data for validation of a 2D conv-div nozzle in mach range 0.2-2.0 DDikeshorn Main CFD Forum 0 January 18, 2017 04:56
ABL simulation with experimental data: problems and doubts Davide_sd OpenFOAM Running, Solving & CFD 0 May 22, 2013 18:35
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
Experimental data urea-water injection crevoise Main CFD Forum 0 November 1, 2011 03:44
