Persistent mass flux error
Old   March 7, 2017, 18:27
Smile Persistent mass flux error
sam
mczero57 is on a distinguished road
Hello Cfders :
This is a somewhat open ended question - I ask it to have some good discussion on this topic.
I am running a steady 2d axisymmetric hypersonic case with a well validated flow solver. The case is the flow around a hypersonic body and there is some unsteadiness due to vortex shedding from the rear of the body. So, the residuals dont go down much. I have checked the y+ values on all walls and they are within the permissible range - I am using wall functions.
When I post-process, I see that the mass flux balance over the whole domain has a -2.8% error. I have tried finer grids, changing the bc to nonreflecting, running it out further, etc. all to no avail.
If this was your case, what else would you try ?
Thanks
Sam
mczero57 is offline   Reply With Quote
Old   March 8, 2017, 06:56
Michael Prinkey
mprinkey will become famous soon enough
How are you post processing? Does the flow solver output face-based mass flux data or are you interpolating that from cell- or node-based data? This can make all of the difference. For cell-based FVM, I like to store the mass flux data on the faces as (somewhat) redundant information specifically for this reason. In principle, you can reproduce the mass fluxes from non-face data, but it will require duplicating, say, the gradient computation for velocity and density, limiting of that gradient, and interpolation to the boundary faces. Off the shelf post processing tools likely won't do exactly the same thing unless it was co-developed with the CFD code.
The second issue is that your problem is NOT steady if you have vortex shedding. The fact that "the residuals dont go down much" indicates to me that you don't have a solution yet.
mprinkey is offline   Reply With Quote
convergence, mass flux
UDF for DPM particle deposition modelingpa haghshenasfard Fluent UDF and Scheme Programming 10 September 15, 2019 02:03
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
