Stepwise Discontinuity problem
Old   February 22, 2000, 23:10
Default Stepwise Discontinuity problem
Alan Kang
I have analysis NACA23012 using FEM fortran software where there is a stepwise discontinuity on upper surface of the NACA23012. We find that the coefficient of pressure of the cut surface is lower compared to the basic airfoil of NACA23012. Why this will happen when the upper surface is being cut on 50%chord and 50% depth? Besides, we have analysis also that the stepwise discontinuity of NACA23012 at 45% and 55%chord of the upper surface. From result, the 45%showed the best lift coefficient from others when the angle of attack is higher than 3 degree. Why the stepwise discontinuity at lower percent of chord having the better lift coefficient? What is the best percent of chord for stepwise discontinuity for NACA23012 so that the best lift coefficient can be obtained.
The mesh we used is using triangular element and the domain or the boundary is for x direction is 20 times chord length and for y direction is 100 times maximum thickness of the airfoil. This airfoil is analysed by solving the equation of stream function and the equation of Bernoulli equation is also applied to calculate the lift coefficient. This analysis is for airfoil in inviscid flow. The following result is what we get for different percent of stepwise discontinuity for the lift coefficient:
0deg 3deg 5deg 8deg 10deg 50% 0.14 0.28 0.46 1.15 1.38 45% 0.03 0.33 0.56 1.31 1.85 55% -0.13 0.15 0.38 0.94 1.15 basic -0.2 0.06 0.33 0.76 0.98
Old   February 22, 2000, 23:46
Default Re: Stepwise Discontinuity problem
John C. Chien
(1). It is hard to understand why the inviscid equation is used to obtain the solution for an airfoil with a step-wise discontinuity on the upper surface. (2). Assuming that the solutions are accurate inviscid solutions, then there's no other explanation for it. (3). Someone will have to do the same thing to get the inviscid solution, in order to validate it. Until then, those are your findings. (4). My suggestion is: try to get some viscous solutions first. It is only a suggestion.
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
Sod Shock Tube problem cfd Main CFD Forum 4 July 7, 2009 13:24
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
