April 27, 2017, 16:00 |
Meshless method for shock capturing
nabizadeh
Rep Power: 13 |
I am trying to implement an RBF meshless method to capture shock waves. I used a Roe's scheme as an upwinding method but my result shows that it is to diffuse. Has anyone used RBF method to capture shock wave? I appreciate it if you could give any suggestion to improve the resolution and better accuracy. |
May 7, 2017, 06:19 |
C. Ziyad
Rep Power: 15 |
I'm working too on the RBF method for problems including schock. You can try to look this references : http://www.sciencedirect.com/science...55799716300108 The mean idea is to combine a upwinding with slope limiter techniques. I thinck also that good results herien are because largest collocation points. |
May 8, 2017, 19:03 |
#3 | |
nabizadeh
Rep Power: 13 |
Thanks for the reply. Actually I used the slope limiter (Van Albada) to find the value at the interface and enhance the accuracy but I think there are some problems with the upwinding implementation. Do you have any idea on how to implement the upwinding scheme for RBFs?
May 15, 2017, 10:02 |
C. Ziyad
Rep Power: 15 |
In the reference above the the implementation of upwind technique are described.
The finite element method - “displacement” or “stiffness” method | 3Lin7 | ANSYS | 0 | February 15, 2013 18:36 |
Control volume based finite difference method? | mukut.medhi | Main CFD Forum | 3 | August 24, 2012 10:01 |
Info on method of lines approach | charlie ryan | Main CFD Forum | 2 | August 9, 2007 11:06 |
smoothed interface capturing method: compressible. | jinwon | Main CFD Forum | 0 | May 14, 2007 00:20 |
tidal flow simulation using finite volume method | Jason Qiu | Main CFD Forum | 0 | October 20, 2002 02:34 |
