May 27, 2017, 17:04 |
RANS for Moving Wall Boundaries
A E
Rep Power: 10 |
Has anyone used RANS for simulating any moving boundaries (no slip walls)? What are disadvantages of RANS for such problems? I am dealing with separations at the wall as well. Thanks, A E |
May 28, 2017, 06:17 |
Filippo Maria Denaro
Rep Power: 71 |
You should consider URANS ... A similar flow problem where URANS is quite common is the flow motion during the cycle of a piston in a cylinder. Check in literature for that
May 29, 2017, 08:01 |
D. N. Venturi
Rep Power: 13 |
A known RANS/URANS model that can treat separation effects is the two-layer k-epsilon. But I don't know if it is good for moving wall.
May 29, 2017, 11:31 |
#4 | |
A E
Rep Power: 10 |
A E |
May 29, 2017, 11:26 |
A E
Rep Power: 10 |
boundary layer, des turbulence model, moving bc, rans modelling, separating wall |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Floating Point Exception - wrong boundaries or general PC problem? – OF 1.6 extend - | A.Wendy | OpenFOAM | 0 | February 27, 2013 04:50 |
How i can create a wall with out boundaries??? | STK | FLUENT | 1 | July 7, 2004 13:20 |
Flux at wall boundaries for Roe's scheme | MyG | Main CFD Forum | 3 | February 14, 2004 03:26 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
