June 12, 2017, 11:44 |
Pressure Drop Pipe Measurement Location
James
I am doing a project where I am modelling fluid flow in pipes and using cfd to calculate the pressure drop around different pipe bends. I am confused as to which point in the pipe cross section to measure the pressure drop. The software I am using allows me to measure the pressure at a specific point or as an averaged value on the pipe cross section. My question is, is the pressure in a pipe usually measured at a point along the pipe centreline, or as an average across the pipe cross section? Thanks. |
June 12, 2017, 17:12 |
Jim Breunig
Rep Power: 8 |
I'd have to say that it depends on what you're doing, but it sounds like you want the drop in static pressure. For that, we measure at a tap along the wall of the pipe.
You can use this in conjunction with a pitot tube to get total pressure. The pitot tube tap would be at pipe centerline, but it sounds like you care about static pressure. Again, it all depends on what you want to see/measure/understand. |
acusolve, cfd, pressure drop |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 12:41 |
Pressure drop in periodic turbluent pipe flow | lou | FLUENT | 0 | September 21, 2005 00:58 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
