June 21, 2017, 18:50 |
Pressure gradient in a smooth pipe
I found in some article that the pressure gradient for a smooth pipe is dp/dx = 0 for fully developed laminar/turbulent flow. If we accept the fact then, there would be no friction at all because the pressure has not been dropped along the length. Can someone explain the theory to me please? May be I am misunderstanding some point. What about the favourable pressure gradient, and I am talking about both laminar and turbulent flows. |
June 22, 2017, 01:00 |
Alex
Rep Power: 46 |
Is "x" the main flow direction? Perhaps a body force instead of a pressure gradient was used to drive the flow. Hard to tell without knowing which article you are referring to.
June 22, 2017, 02:04 |
Ok, I even do not remember exactly that where I read this. But, irrespective of this, what happens in reality, if dp/dx = 0 for fully developed laminar / turbulent. If yes, then why do we get a pressure drop along the length? (experimentally and numerically)
June 22, 2017, 02:23 |
Lucky
Rep Power: 66 |
dp/dx is non-zero for laminar and turbulent fully developed flows in a pipe. What's there to explain? You should read carefully your article.
June 22, 2017, 10:30 |
Troy Snyder
Rep Power: 18 |
To reiterate LuckyTran,
The streamwise pressure gradient (dp/dx) is non-zero in pipe flow. In the case of fully developed pipe flow (laminar or turbulent), the pressure gradient balances the shear developed at the pipe walls. The wall shear is non-zero given that the velocity does vary across the pipe, i.e. du/dy is non-zero. The condition for "fully-developed" is that the streamwise velocity gradient is zero (du/dx = 0). |
June 22, 2017, 12:20 |
#6 | |
Filippo Maria Denaro
Rep Power: 71 |
Maybe this condition you read is prescribed at the outflow?? |
negative pressure gradient in cone-shaped pipe | Pawel Zdunek | Lounge | 0 | April 29, 2017 15:16 |
total pressure change in a pipe flow | Im | FLUENT | 5 | February 23, 2017 08:55 |
pipe with orifice, pressure drop declines when pipe gets longer (BC problem?) | cristopf | OpenFOAM Running, Solving & CFD | 0 | January 21, 2016 04:55 |
vortex cause pressure gradient or pressure gradient induce vortex? | fruitkiwi | Main CFD Forum | 4 | June 12, 2012 01:12 |
pulsating static pressure around zero at pipe flow | David Kim | FLUENT | 0 | May 16, 2006 13:47 |
