Stagnation enthapy loss in subsonic adiabatic flow using RANS CFD |
July 5, 2017, 04:55 |
Peter
Rep Power: 12 |
A plate problem is used here, Ma=0.1466, Re=6.68E6, T=286.72.
A RANS solver is used here with Jameson central scheme and artificial dissipation, RK solver. Flow is steady and fully turbulent. NASA turbulence verification plate mesh is used(about 500*300 mesh points). Viscous adiabatic wall BC, subsonic inflow and outflow BC and farfield BC are imposed on mesh boundaries. According to aerodynamic theory, the total enthapy of adiabatic flow should be constant. But in our reaults, the total enthapy of free stream is 290125(SI dimension) and total enthapy in the flow field is about 290300 to 282000(different value at each mesh point) which means total enthapy loss at some locations. Does anyone have knowledge about why this happens? |
July 5, 2017, 05:11 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
July 5, 2017, 20:47 |
Peter
Rep Power: 12 |
Hi Denaro, thank you for looking at this. I need to use stagnation enthapy for later calculation of some other variables so I am trying to figure out whether CFD can reflect the physics and calculate stagnation enthapy in the right way. Although CFD is viscous and dissipative, it is adibatic, so stagnation enthapy should be constant.
July 6, 2017, 02:51 |
Rep Power: 71 |
If you consider the Crocco theorem, the assumptions are that the flow has no dissipative effects (stress and heat transfer) and is steady. The total enthaply will obey the relation
Grad H + (curl v) x v =T Grad s Furthermore, do not forget that in your turbulence model, the energy has the unresolved terms modelled as additional dissipation-like |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
CFD Symposium (Call for Papers) | Chris R. Kleijn | Main CFD Forum | 0 | October 5, 1998 10:25 |
ASME CFD Symposium - Call for Papers | Chris R. Kleijn | Main CFD Forum | 0 | September 8, 1998 08:19 |
ASME CFD Symposium - Call for Papers | Chris R. Kleijn | Main CFD Forum | 0 | September 3, 1998 08:45 |
