Given rotational symmetry around X axis, how can XY possibly differ from XZ? |
June 23, 2017, 21:50 |
Anon
Rep Power: 8 |
I have a 3D model of a sphere in a cylindrical fluid channel. The sphere is at the dead center of the channel. Fluid flow is along the X axis, and this is Stokes flow, so no turbulence. The model is not set up using an actual symmetry function, but it is inherently symmetric about X.
It would seem to me that in this case, the XY plane and the XZ plane are exactly the same -- rotate the model 90 degrees in the proper direction, replace "Y" with "Z", and theta with phi, in the equations, and you literally should not be able to tell the difference. But, it doesn't work. I can solve for translational velocity in X, Y and Z, and I can solve for rotational velocity in XY. But, if I try to solve for rotation in XZ (which should essentially be 0, and is essentially 0 in XY), I get crazy solutions (sometimes > 10,000 rad/sec). Additionally, the XZ solutions bounce around randomly if I change the mesh settings, whereas the XY solutions do not. How is this possible?? Is there some formalism, perhaps of vector direction or sign, that makes Z different than Y? Here is a screenshot of the geometry, most of the variables that go into it, and the results at the bottom when solving for translation in all axis, and rotation in XY: https://www.dropbox.com/s/l8zmmrx2wo...hot-1.png?dl=0 Here is the result when I also try to solve for rotation in XZ (note that it is not the combination that is the problem -- solving for only XZ doesn't work either, just showing a combined version to illustrate the equations I am using): https://www.dropbox.com/s/601uhx38xr...hot-2.png?dl=0 Last edited by MultiPhy; June 23, 2017 at 22:25. Reason: Add second screenshot |
June 24, 2017, 23:07 |
Anon
Rep Power: 8 |
I fixed this, but although my equations were wrong, they were consistent in XY versus XZ, so I still wonder why the two planes of rotation gave totally different answers.
Axis Symmetry BC | Manish Kumar | FLUENT | 6 | May 26, 2023 12:00 |
axis symmetry for a cylinder is possible in cfx. | umair64 | CFX | 1 | August 15, 2015 06:05 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
Symmetry or Axis B.C ?? | L. Hamid | Main CFD Forum | 2 | May 20, 2011 06:27 |
Defining a moving rotational axis! | Samuel | CFX | 3 | September 12, 2007 10:00 |
