July 4, 2017, 10:21 |
Advice on projection/fractional step methods
David
Rep Power: 9 |
Dear all,
I have a fully coupled unsteady FEM Navier-Stokes code, used in the context of hemodynamics, in particular flow through stenosis with Reynolds numbers of the order of ~2500. (I suspect the flow to be near transition; LES will be carried out later to confirm.) I'd like to implement projection/fractional step/splitting methods for efficiency. There are many schemes and many names in the game, so I'd like to ask about your experiences and recommendations. What are your favorites? In particular: implicit or explicit convection? Pressure treatment? Thanks for your advice! Regards David |
July 4, 2017, 11:22 |
Filippo Maria Denaro
Rep Power: 71 |
I always used the pressure-free projection method... Second order in time using explicit for the convection and the SGS terms and implicit for the diffusion.
July 4, 2017, 17:09 |
David
Rep Power: 9 |
Thanks for your comment. Can you elaborate on why you chose pressure-free (e.g. instead of incremental pressure correction)?
Are there any considerations w.r.t. BDF2 vs. Crank-Nicolson? Thanks |
July 4, 2017, 17:32 |
#4 | |
Rep Power: 71 |
In general, when well-formulated, these fractional methods are all quite good. A detailed analysis of each method does not lead to a definition of the "best one". I can say that each method produces a different meaning of the "pressure" field. Then, BDF2 vs. Crank-Nicolson is something related only to the solution of the intermediate momentum equation. The CN scheme produces a stable solution and allows to work with reasonable time-step. The intermediate velocity must be prescribed at the boundary and this is, however, an issue to consider carefully. The BDF2 I used (Adams-Bashforth) is stable provided that the time-step is constrained by the (cfl-Re_h) stability region. You can find a lot of published literature about that. |
fem, fractional step, projection method |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
How to use PIMPLE properly? | floquation | OpenFOAM Running, Solving & CFD | 25 | December 2, 2021 09:40 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
