Monitoring residuals , is it safe ?
Like Tree13Likes
Old   July 13, 2017, 10:26
Default Monitoring residuals , is it safe ?
dilaw meda
medaouarwalid is on a distinguished road
Hi, i read that monitoring only the residuals can be treaky, and we should monitoring also values on interest, in my case velocity and temperature. By monitoring those values, how can we say that the solution is converged ? When the values dont change any more or when it becomes close to experimental results ? Or what ? Also, what are the acceptable values of residuals that can be published for continuity, velocity and energy
medaouarwalid is offline   Reply With Quote
Old   July 13, 2017, 10:37
BlnPhoenix is on a distinguished road
Transient or steady state simulation?
medaouarwalid likes this.
BlnPhoenix is offline   Reply With Quote
Old   July 13, 2017, 10:46
dilaw meda
Transient LES
Sent from my F1f using CFD Online Forum mobile app
Old   July 13, 2017, 11:01
You need to define what convergence means to you.
e.g. if you monitor temperature you can define convergence as: the calculated solution for temperature in each time step changes only in the second decimal place behind the comma. You need to get a feeling how exact your solutions per time step need to be. If you study convergence levels you will see that the change in temperature in each time step correlates to the level the residuals reach. So you can set automatic convergence detection if you know let's say for example that 1e-4 in residuals for energy translates to a max change in temperature in the xyz place behind the comma. You have to find that out for yourself.
Old   July 13, 2017, 11:07
dilaw meda
But when i took the mesures of temperature in experiance, i didnt took it with a fix time step so i have no idea how much it must be changing each timstep, althought i have an idea how much it changes every z/d , because i took temperature mesurements with velocity, each time i mesured velocity i mesured also temperature. I hope you understood me
Old   July 13, 2017, 11:08
Also for continuity. I usually accept a mass imbalance of < 0.1% as acceptable. Again this translates into a value for continuity residuals. Maybe something like 1e-4 or less. You need to check this.
Old   July 13, 2017, 11:11
dilaw meda
I am doing an example wright now, all residuals are less than 10^-5 exept for continuity it dident reach 10^-4 i dont know why
Old   July 13, 2017, 11:15
How long is your experimental time? When did you measure and how often?
You can simulate until maybe you first measured your temperature in experiment. If you measured first after 5 mins. simulate 5 mins. Also how exact is you measurement device? If you now the uncertainty in your measurements, you do need to be more exact in simulation than your measurement device.
Old   July 13, 2017, 11:17
Check mass imbalance in your system, if your satisified. It sounds OK to me.
Old   July 13, 2017, 11:20
dilaw meda
Time of experimental was about an hour Because i took the velocities in 20 axial stations and for each axial station a go for 10 stations radially . I dont think that i can do a 1 hour of simulation because i am setting the time step = 10^-5 . If i can reac 10 seconds of simulation i am lucky 😥
The device is velocicalc
[IMG]lghttp.17652.nexcesscdn.net/808B15/magento/media/catalog/product/cache/8/image/500x500/ae8e27adf667b20d5f3db4b7e3a38cc2/9/5/9555_app.jpg[/IMG]
dilaw meda
What mass imbalance means ?
Old   July 13, 2017, 11:22
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Since you are doing an LES, what you call residuals are only the terms you have in each time step in the formulation for solving the system of the equations. Now that depends on the choice of the formulation, are you using a full compressible flow solver? In such a case what about the Mach number? Are the residuals normalized?
FMDenaro is offline   Reply With Quote
Old   July 13, 2017, 11:29
dilaw meda
I am suppozing that the flow is incompressible because the velocity inlet is lot less than speed of sound. (6.66 m/s) so much number is 0.02
Residuals are not normalized
Old   July 13, 2017, 11:47
Your case will be stiff using a compressible flow model. Are you preconditioning the equations? Could you switch to a pure incompressible solver? Try to evaluate the normalized residuals
Old   July 13, 2017, 11:53
dilaw meda
Excuse me but I didn't understand .
Old   July 13, 2017, 12:21
I think I cannot help you if you are not aware about these issues? What about your background in CFD?
Old   July 13, 2017, 12:35
dilaw meda
Not very good, everdy day i learn something new, what should i learn now?
Old   July 13, 2017, 12:46
You should attend a couple of course in fluid mechanics and CFD ... there are a lot of CFD textbooks, each one has some peculiarity and some issues more detalined than others. However, it requires some effort and some years to be good in CFD....
Old   July 13, 2017, 13:19
dilaw meda
I stied and i am studying but of corse i can not know every thing. thats why i ask lot of​ questions, like this i am progressing every day. I have a simulation to do , i can not wait until i read every thing, i only have to understand things that have relation with my case, and with time i will learn more and more about other things
Old   July 13, 2017, 13:59
So did you find some average temperature in your experiment? Have you measured exactly after one hour? Try to describe your experimental findings. Is the temperature constant over time, if yes what do you expect if you would measure after five minutes? Same temp as after one hour?
If you cannot afford the simulation to run to one hour, i would concider redoing your measurements and run it till you have experimental data to compare.
Mass imbalance means that the mass flow in the systems equals the mass flow out of the system. It's very important to ensure mass balance in every time step. So please check for that and as mentioned set your target residual values accordingly. Also for temperature and velocities as i described above. Your residuals sound good but try to look for the actual change in values to see what they actually mean.
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 09:23
Monitoring Residuals - Initial or Final? BigPapi34 OpenFOAM Running, Solving & CFD 1 November 3, 2014 05:31
Monitoring Residuals - Initial or Final? BigPapi34 Main CFD Forum 0 November 3, 2014 05:23
Monitoring residuals in Workbench-Fluent using Remote Solver fadiga Main CFD Forum 2 October 16, 2013 15:43
judging convergence through residuals MachZero Main CFD Forum 7 December 25, 2012 12:18
