July 24, 2017, 16:29 |
#41 | |
dilaw meda
Rep Power: 8 |
Sent from my F1f using CFD Online Forum mobile app |
August 31, 2017, 11:04 |
#42 |
dilaw meda
Rep Power: 8 |
Hello professors, i hope you remeber me, i took a period of rest and i am back now. I did some changes on the boundary conditions also for the mesh, i am using the default mesh generating by ansys software with little modification on the size of the elements. I used the kepsilon, k omega and RSM models. Here the results on the axial velocity . Numbers of elements was 3.2 million. What can you Say about the results
August 31, 2017, 11:55 |
#43 |
Filippo Maria Denaro
Rep Power: 71 |
Not bad, the discrepancy is more relevant for increasing z/D. But one should be sure about the experimental measurements.
August 31, 2017, 12:52 |
#44 |
Rep Power: 13 |
Looking good so far. I think with RANS you can obtain a good solution. As FMDenaro said maybe check measurements again, check the reproducibility of experimental data. From there you can try to make a mesh study. I would say apart from k epsilon the turbulence models look simliar. I would stick to one an try to optimize further. Are you happy so far with the results?
August 31, 2017, 15:27 |
#45 | |
dilaw meda
Rep Power: 8 |
September 5, 2017, 07:59 |
#46 |
dilaw meda
Rep Power: 8 |
Hi , this is the mesh study for the three turbulence models . Should i do an Other mesh ?
Sent from my F1f using CFD Online Forum mobile app Last edited by medaouarwalid; September 5, 2017 at 09:08. |
September 7, 2017, 04:25 |
#47 |
dilaw meda
Rep Power: 8 |
As you see velocities results were acceptable, my problem now is with the temperature, all points are the same there is no difference or decrease . Any help please !!
Guide to set initial parameters and settings for external flow simulation | amarnath_sivasubramanian | FloEFD, FloWorks & FloTHERM | 1 | August 6, 2015 01:43 |
