2D-flow in a tube: Continuity and Navier-Stokes |
August 9, 2017, 12:55 |
Rep Power: 8 |
Hi people,
I want to do some basic stuff with Python 2.7 an the finite differences method. Now I have the following case: - 2D-flow in a tube, steady state, not compressible - at the inlet there ist a constant velocity profile so () - the flow is developing into a convex profile I want to find out the length "L" of the tube, where the velocity profile isn't developing any more. The basic equation for continuity and Navier-Stokes are: An assumption is, that I say the velocity "v" is everywhere zero. So every term with "v" in the Navier-Stokes and Continuity equation is zero and I have to solve only the u-Momentum (as shown). In addition to this I say that is also zero. After this assumptions I have these equations left (Continuity and navier-stokes): If I look to my continuity equation and insert it into the navier-stokes, there is: So in my eyes it doesn't make sense ? It means: The velocity profile is not dependent on the fluid. So it doesn't matter, if there is water or air ? I don't think so.(?) I tried the case without inserting and I solved the equation in Python. It works and there are meaningful results. But I don't understand. Actually I have to insert the continuity into the Navier-stokes, isn't it ? |
August 10, 2017, 15:31 |
Rep Power: 18 |
For steady continuity a non-zero gradient du/dx in the flow will have to be accompanied by a non-zero dv/dy, hence v cannot be zero everywhere. I think you have made too many assumptions and the apparent conflict in your results is indicative of this. Once you reach fully developed flow, du/dx is zero and the pressure gradient is balanced by the viscous stress. Then v is zero. But in the development region you cannot make this assumption.
August 10, 2017, 16:03 |
Filippo Maria Denaro
Rep Power: 71 |
What you are trying to do is the study of the developing boundary layer along a flat plate (top and bottom walls), so you have to use the Prandtl equations.
Just consider that the flow evolves until the thickness of the BL is equal to H/2 (H the distance between the two walls). You can use the law delta(x) to compute this lenght that depends on the viscosity of the fluid (or Re number). A FD solver can be used to check the theory. |
August 10, 2017, 16:47 |
Lucky
Rep Power: 66 |
You've made way too many assumptions. Your solution is u=constant everywhere, which doesn't even make sense.
du/dy=0 is only at the inlet, not everywhere. This should be obvious in a pipe flow because u=something at the inlet but u=0 on walls because of the no-slip condition. From where do you get dp/dx=0 ? Even for a flat plate dp/dx is not zero and for a pipe it must eventually be a non-zero constant when the flow in the pipe is fully developed. From where do you get v = 0? This is the advection-diffusion equation for a parallel flow (flows very small gradients in the y direction). If you solve this equation, you will indeed get a result that looks like a flow because it is an advection equation. But it has limitations. For learning finite differences this is actually a really good equation to try and solve because it contains non-linear advection on top of diffusion. Usually diffusion problems are 1st problem introduced. |
August 11, 2017, 09:42 |
I think you should not make any assumption since the velocity is developing.
Steady Incompressible Navier Stokes | selim | CFX | 0 | October 24, 2007 07:52 |
continuity & navier stokes.... | Louise | FLUENT | 2 | March 2, 2007 10:57 |
ILU for Navier stokes problems | Raju | Main CFD Forum | 5 | July 29, 2006 14:15 |
Navier stokes compresible viscid flow fea, somebody can help? | Jose Choy | Main CFD Forum | 3 | October 24, 2003 02:28 |
help: I am trying to solve Navier Stokes compressible and viscid flow | Jose Choy | Main CFD Forum | 2 | May 18, 2000 05:45 |
