K-Epsilon model
Old   August 17, 2017, 12:03
Default K-Epsilon model
Selig
selig5576 is on a distinguished road
For the K-Epsilon, model I am unsure how to appropriately discretize the production term (image attached). I am currently trying 2nd-order central differencing of the terms to retain second order accuracy, however I know that it will run into issues for high Reynolds numbers. I was curious if this was sufficient given I don't yet want to do any type of WENO or ENO.
EDIT: To clarify and give substance to this topic.
1. What I am curious about is if central differencing of the production term is sufficient.
2. Something I am confused about is how in Griebel's book he performs some type of mixed finite differencing on the 2D production term (eqn 10.31 and its U velocity counter part), which I don't understand given there is no mixed derivatives.
selig5576 is offline   Reply With Quote
Old   August 18, 2017, 12:43
Default K-Epsilon FVM
Selig
Any suggestions or thoughts?
Old   August 18, 2017, 13:06
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
I have no personal experience about this modelling, however my general opinion is that you should consider using the same spatial operators you used for the other terms. In general, that depends also on the use of either FD or FV methods. In the latter, you have to consider the volume integral of the production term.
For the time integration you have to consider that a production term can become stiff and cause problems in the numerical stability.
FMDenaro is offline   Reply With Quote
Old   August 20, 2017, 08:09
Hamid Zoka
Hamidzoka is on a distinguished road
I have a prior experience in FV with other turbulence models.
The integral form of the production term at cell boundaries needs to approximate velocity derivatives and a central scheme will be a proper choice for that.
Hamidzoka is offline   Reply With Quote
At high Y+ values does the K Omega SST model just behave like the K Epsilon model? JuPa CFX 0 December 22, 2015 06:44
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
epsilon and K blowing up. sivakumar OpenFOAM Running, Solving & CFD 1 October 25, 2012 04:50
k and epsilon discretization of RNG model mehran Fidelity CFD 0 January 24, 2009 00:01
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
