Thermal cooling
Old   September 1, 2017, 05:11
Default Thermal cooling
Tutulikasaha is on a distinguished road
Hello all,
I am doing a conjugate heat transfer problem . Analysis of a cold plate for cooling of electronic equipment
The flow rate of coolant is 1 GPM and temperature is 22. I have run the analysis for varied temperature of coolant and got good results.
But when i tried with the same model and same temperature for coolant with different flow rate i.e 2 GPM ..the results for 22 degrees to 27 degrees is same.
How this is possible. My all other parameters are same. Heat source same.
Location and each and every boundary conditions are same
Please comment.
Sent from my Nexus 4 using CFD Online Forum mobile app
Tutulikasaha is offline   Reply With Quote
chtMultiRegionSimpleFoam: Thermal Conduction + Surface-To-Surface Radiation Zeppo OpenFOAM Running, Solving & CFD 16 May 18, 2017 18:04
Thermal cooling analysis sanjeevkumar patne FLUENT 6 December 6, 2016 01:34
Thermal conductivity issue Jared1986 CFX 3 March 20, 2014 10:38
Thermal performance of spray cooling pond simulati Zhang Zhiqin Phoenics 0 December 20, 2002 02:50
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
