Simulating solid particles in fluid using VOF method
Old   October 15, 2017, 16:53
Default Simulating solid particles in fluid using VOF method
Mohammad Sobhani
moh.sob is on a distinguished road
I want to simulate motion of solid particles in a newtonian fluid. Is it possible to define a fluid with high viscosity and high surface tension instead of solid particles and then solve the problem with VOF multiphase model?
moh.sob is offline   Reply With Quote
Old   October 16, 2017, 00:20
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
This approach is possible but has limitations: Fluid "particles" of this properties get always round. You cannot simulate any effects which depend on the shape of the particles.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   October 16, 2017, 02:28
France - Alsace
nourlil is on a distinguished road
You have to use FSI (Fluid-solid interaction) to solve phenomena so you have te define degrees of freedom to particles but overset mesh is needed in this case of simulation
nourlil is offline   Reply With Quote
solid particles, vof multiphase
chtMultiRegionFoam connection between solid and fluid region of heat exchanger ahab OpenFOAM 1 December 18, 2019 00:37
Simulating discrete solid phase inside a continuous fluid phase hosseinamir71 CONVERGE 1 August 31, 2017 16:02
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? RPjack ANSYS Meshing & Geometry 2 August 27, 2015 09:33
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
heat conducting solid within a fluid medium? sieginc. STAR-CCM+ 1 February 19, 2012 11:48
