Temp. and Pressure aft combustion
Old   October 20, 2017, 00:50
Default Temp. and Pressure aft combustion
Myoungjin Kim
Comb3112 is on a distinguished road
hi
I'm using nasa cea program(GUI ver) for rocket problem.
In my lab, I'm designing the rocket nozzle, with Al and air under 2Bar atmosphere.
Commonsensically, after combustion, the pressure and temperature would rise. and these value will contribute to the nozzle design parameter such as P0 and T0(the subscript 0 means total properties).
However, if i run the CEA code with given initial pressure(2Bar), the output shows same pressure value, 2Bar. and the error shows that - WARNING!! CALCULATIONS WERE STOPPED BECAUSE NEXT POINT IS MORE THAN 50 K BELOW THE TEMPERATURE RANGE OF A CONDENSED SPECIES (ROCKET) -
If i change the reactant to O2(gaseous species), there are no error messages but the pressure value shows same.
I cant understand why the pressure output after combustion shows the same value.
How can I get the pressure value after combustion?
Comb3112 is offline   Reply With Quote
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle cdm OpenFOAM Running, Solving & CFD 7 August 28, 2019 01:37
Pressure loss Velocity coupling CFXMUFFIN CFX 1 February 6, 2016 04:43
Gasoline Vapor pressure at 60 deg Temp saravana CFX 1 January 22, 2012 06:29
Temp & Pressure jump at&near wall during iteration dokeun FLUENT 1 April 19, 2011 02:04
Simple Temp and Pressure Q Cb Siemens 4 February 21, 2005 02:58
