need help with natural convection problem
Old   October 18, 2017, 21:37
Lightbulb need help with natural convection problem
heesang Yoo
yhs0365 is on a distinguished road
hello everyone
I am having trouble with solving simple natural convection problem.
The problem is that momentum residual is so high and do not go down...
I attached my design image... the red one is heat source so maybe there has to be movement of inner gas, circulation around heat source
When I set laminar model and set initial velocity as 0m/s momentum residual was as below momentum residual.png
and velocity profile was very dirty...
for example region that has to be have downstream had upstream and so on...
so i ask for colleague how to reduce momentum residual he said that I have to change turbulence model or set initial velocity as twice of my goal velocity
so I set k-e model (because it's residual was lower than sst) and set initial velocity as 0.1m/s.
then, momentum and turbulence residual were as below
velocity profile was clearer than before but, still momentum residual has to be lower and velocity profile was still incorrect.
is there somebody know well about natural convection?
and is there other factors to lower momentum residual and make clear velocity profile??
thank u!
yhs0365 is offline   Reply With Quote
Old   October 18, 2017, 22:54
Lane Carasik
lcarasik is on a distinguished road
Originally Posted by yhs0365 View Post
hello everyone
Attachment 59081
When I set laminar model and set initial velocity as 0m/s momentum residual was as below Attachment 59082
Attachment 59083
Attachment 59084
thank u!
Is your flow in a turbulent regime for natural convection? If not, it probably isn't a correct assumption to be using a RANS formulation.
How are you accounting for density changes? Is gravity set in the correct direction? Are you properly resolving the highest gradients in your flow?
lcarasik is offline   Reply With Quote
Old   October 20, 2017, 02:14
Unhappy
heesang Yoo
thanks for reply.
It is natural convection so, I couldn't know whether the flow is turbulent or laminar. So, I assumed the flow as laminar flow but, its reynold's number was far larger than 2300 so, I set the flow as turbulent flow.
i made fluid properties (conductivity,viscosity, density, heat capacity) as function of temperature.
also, I set gravity as -9.8m/s^2
and i can't understand ur last sentence... resolve highest gradient of flow?? what's that mean?
now I'm trying various trials to make residual lower. such as increasing heat transfer coefficient, make pressure loss 0 in porous media...etc...
but, I can't lower momentum residual more below than 1e-2...
Old   October 20, 2017, 02:16
Lane Carasik
thanks for reply.
How are you calculating your Reynolds number? If it is natural convection, you should be using a Raleigh or Grashof number.
Old   October 20, 2017, 03:01
heesang Yoo
oh sorry... I mean rayleigh number... I wrote it by mistake
it is far larger than 1e9
ansys, cfd, cfx, momentum residual, natural convection
Convergence issue in natural convection problem chrisf90 FLUENT 5 March 5, 2016 08:30
Natural convection problem kez FLUENT 0 February 22, 2016 17:02
Problem in laminar natural convection in cavity realfear FLUENT 6 June 27, 2014 10:47
Natural convection problem in CFX 11 Willy CFX 2 May 23, 2008 23:12
ON TURBULET MODEL FOR A NATURAL CONVECTION PROBLEM varghese FLUENT 6 February 6, 2002 05:23
