potential flows, helmholtz decomposition and other stuffs |
Rep Power: 11 ![]() |
Hi I'm studying potential flow theory and I'd like too deeply understood this issue. I will present here the main lines of the theory in three points, as I have understood it, and some open questions for which I don't find an answer.
1) the equations that govern the behaviour of a steady, inviscid, incompressible and irrotational flow with conservative mass force field are: ![]() ![]() on the boundaries the only condition required is to impose the normal component of the velocity: ![]() the hypothesis ![]() ![]() ![]() ![]() ![]() 2) Potential formulation. We can prove, using stoke's theorem, that every irrotational vectorial field defined over a simply connected domain is conservative. This allow us to rapresent the velocity as the gradient of a scalar potential field: ![]() where the potential is defined with the following line integral where the path has to be contained inside the domain : ![]() where ![]() ![]() ![]() with the boundary condition: ![]() so in this case we are allowed to solve the laplace equation for ![]() ![]() ![]() ![]() ![]() 3) Helmholtz decomposition. Another well known result is that any kind of vectorial field defined in a simply connected domain can be decompose in the following way: ![]() This decomposition is not unique because if we find two fields ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() my interpretation of the former statement is that a vectorial field ![]() ![]() ![]() ![]() ![]() Now some questions. - dealing with point 1 and 2 In point one we can find a unique velocity field solving the whole system of equation while the pressure field remain undetermined unless a constant. In point two we can find a unique velocity field solving the sole laplace equation and the field of the scalar potential remain undetermined unless a constant. Here I see a sort of symmetry between the two cases. In this kind of problem the pressure is not the thermodynamic pressure ( because the flow is considered as incompressible) and some book adress the pressure as a lagrangian multipler, so a kind of mathematical element inside the problem. Is there some relation between the physical meaning of pressure and the physical meaning of the scalar potential? - dealing with point 1 and 3 In point three we have find out that a vectorial field ![]() ![]() ![]() ![]() ![]() ![]() ![]() - dealing with point 2 and 3 In point two we have defined a scalar potential field starting from the assumption that the field of velocity is conservative, while in point three we have defined a scalar and a vectorial potential fields that are able to decopose a generic vectorial field. Is it possible to modify the explicit statement of the helmholtz decomposition under the assumption of solenoidal and irrotational field to reach the definition of the scalar potential presented in point two? I have waste some time on this issue but the two definitions look so different... How to reduce non-local integrals defined on a close surface to a line integral. The last question If we know that a velocity field is irrotational and solenoidal and moreover if we know the value of the normal component of the velocity on the boundaries what can we say about the tangential component of the velocity? It looks to be in some way constrained, but what is the explicit relation? I have tried to decompose the velocity on the boundaries using the relation: ![]() considering the first term as known and replacing the former statement inside ![]() ![]() I hope someone can help me to clarify one or more of these issues. Thanks. |
Filippo Maria Denaro
Rep Power: 71 ![]() ![]() ![]() |
What you are asking is intrinsic to the Helmholts-Hodge decomposition that is unique and orthogonal. Setting only one component is required to have the problem amthematically well posed. However, depending on the decomposition you can use either normal or tangential BC.s.
If you are interested in some theoretical details related to the NS equations for incompressible flow you can find them in https://www.researchgate.net/publica...ary_conditions |
