Derivation of momentum equation for newtonian fluid in cylindrical coordinates
Like Tree1Likes
  • 1 Post By FMDenaro
Old   December 11, 2017, 09:03
Default Derivation of momentum equation for newtonian fluid in cylindrical coordinates
Robin Kamenicky
Robin.Kamenicky is on a distinguished road
Hi everybody,
Would anyone have some tip for source, where would be complete derivation of momentum equation for newtonian fluid in cylindrical coordinates?
Thank you,
Rob
Robin.Kamenicky is offline   Reply With Quote
Old   December 11, 2017, 11:21
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Robin.Kamenicky View Post
Hi everybody,
Thank you,
Rob
Many basic fluid dynamic textbooks illustrate the NS equation in cylindrical coordinates, do you need only the expression or do you want to understand how the expression is derived from the general vector formulation?
lcarasik likes this.
FMDenaro is offline   Reply With Quote
Old   December 12, 2017, 08:01
Robin Kamenicky
Hi FMDenaro,
First of all, thank you for the reply.
I would like the entire derivation of differential form from scratch.
I would like to see wether the area of the finite element faces are different. I saw different approaches to this. In one source, the faces in r direction were computed r*dangle*dz and (r+dr)*dangle*dz and in another one they assumed to have same areas. Sure, smaller the element, the more similar areas.
Also the derivation of viscous stress components would be interesting to see.
I checked following document where in r direction, the normal stress in the angle direction is added. I do not understand the reason for it.
Overall, I feel I quite understand the derivation but there are some small nuances in which I am not 100% sure. So I would appreciate a source as detailed as possible.
Old   December 12, 2017, 11:39
You can find some explanations but they are quite equivalent each other.
I generally introduce to my student the general vector notation for the expressing the equation (valid for any type of reference system) and them express the components of the vectors and differential operators in the chosen reference system.
For example:
v= ir *vr+ itheta *vtheta+iz*vz
and the differential operator
nabla = ir *d/dr+ itheta *(1/r)*d/dtheta+iz*d/dz
(see https://en.wikipedia.org/wiki/Del_in...al_coordinates) so that for example the divergence of the velocity is
(ir *d/dr+ itheta *(1/r)*d/dtheta+iz*d/dz).(ir *vr+ itheta *vtheta+iz*vz)
and now you have to extend the expression using the rules for the products and derivatives.
The same procedure is applied for the gradient of both a scalar and vector function.
conservation of momentum, cylindrical coordinates, newtonian fluid, theory
Finite Volume Method For Cylindrical Coordinates falopsy Main CFD Forum 45 August 14, 2023 21:14
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Derivation of Momentum Equation jbambery Main CFD Forum 1 June 9, 2006 13:27
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
