November 23, 2017, 04:35 |
Turbulent shallow water flow
C. Ziyad
Rep Power: 15 |
Hello everyone,
With an algebraic (Mixing lenght) turbulent shallow water flow, I can not see recirculation developed around an obstacle. My simple question is: can the number of mesh have an effect on the capturing of turbulent behavior? or I have to use other models? Thanks. |
November 23, 2017, 07:51 |
Filippo Maria Denaro
Rep Power: 71 |
Please post the plot of the solution
November 23, 2017, 09:54 |
C. Ziyad
Rep Power: 15 |
with pleasure
November 23, 2017, 11:16 |
Rep Power: 71 |
Well, the grid resolution appears very coarse but that depends on the Reynolds number of the flow. Are you sure that the run is convergent?
However, if you are using RANS then you would not be so surprised that you do not capture a great recirculating region behind the bluff body. |
November 23, 2017, 11:36 |
C. Ziyad
Rep Power: 15 |
I'm not sure for the convergence, because I'm not the responsable of the runs. I'll check this point.
Indeed, I use the RANS model. Is this the problem ? Thank You |
November 23, 2017, 11:46 |
#6 | |
Rep Power: 71 |
What is the goal of the simulation? If you want to observe the vortex shedding, RANS is not the correct formulation. |
November 23, 2017, 11:52 |
C. Ziyad
Rep Power: 15 |
We want to develop a numerical scheme based finite volume method for the tubulence shallow water flows. We start with the RANS model involving many turbulence models (Minxing lenght) and K-epsilon model. As an example we try to compare all on a wake turbulent.
November 27, 2017, 11:20 |
France - Alsace
Rep Power: 8 |
Firstly i think mesh size around obstacle don't have good quality, you can keep actually size of mesh on the geometry but you have to refine it around obstacle. mesh.PNG result.PNG |
November 27, 2017, 14:32 |
#9 |
Uwe Pilz
Rep Power: 15 |
I don't recommend triangular meshes because they are very diffusive. Your problem may be meshed without any problems with hex elements.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
November 28, 2017, 04:01 |
#10 |
France - Alsace
Rep Power: 8 |
Due to simple probleme and geometry he can do it with 3D so i recommand you to use tetraedral element and insert prism layer on the wall and around obstacle to obtain the effect of viscous forces near the wall. |
November 28, 2017, 04:11 |
#11 |
C. Ziyad
Rep Power: 15 |
Thanks all for the replys
Nourlil, I appreciate your remark to refine near obstacl, I well do it and post results. Piu58, I have all time the problem of numerical dissipation but I never had the idea that the rectangular mesh is little diffusive. Sadly, I work with a personal code, is mush diffuclte for me tu converte to a rectangular mesh only for this problem. |
November 29, 2017, 10:51 |
#12 | |
France - Alsace
Rep Power: 8 |
Best, |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
setting for shallow water | nurul aqilah | Fidelity CFD | 0 | December 7, 2015 20:44 |
Is it a turbulent flow or laminar flow? | ringtail | Main CFD Forum | 9 | January 22, 2015 19:52 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
