December 22, 2017, 10:25 |
calculating forces coeff
A. Min
Rep Power: 12 |
Hi
I want to calculate forces for viscoelastic fluid flow. According to what I found out, just I should change the "fT" , i.e. tangential force. in forces.C code we can see: -etaS*dev(twoSymm(fvc::grad(U))); for shear stress. I have three questions: 1- why did it use deviatoric form of twoSymm(fvc::grad(U)) tensor? As you know the shear stress tensor is calculated by: -etaS*twoSymm(fvc::grad(U)) why deviatoric?! 2- why did it use minus in formula? 3- if I want to add it polymer stress tensor, what should I do? is it enough to write: (+ or - ??)tau - etaS*dev(twoSymm(fvc::grad(U))); thanks |
forces, openfoam, viscoelastic |
Help! problems in calculating forces with SimpleFoam | DLC | OpenFOAM | 3 | April 25, 2022 23:43 |
Problem calculating forces on blades 2 (for finding forces) | bye bye my blue | OpenFOAM Running, Solving & CFD | 16 | April 19, 2018 10:48 |
problem with plotting both forces and coeff | giammy92 | OpenFOAM Post-Processing | 2 | March 23, 2016 04:25 |
Calculating forces on a non-closed surface | ScottN | FLUENT | 0 | March 1, 2011 17:18 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
