Hardeep Singh
Rep Power: 8 ![]() |
I was checking some previous post, for finding some good results. I probably find the answer but i have some problem with the notations.
[QUOTE=fierceyeo;308327]Hi, I am new to UDF. So, in order to write these functions.. "h = heat_flux / (T(z) - Tbulk(z)) Tbulk = SUM mu*cp*rho*Tf dA / SUM mu*cp*dA" how to I define these variables "mu, cp, rho"? and is this equation applicable for 2D problem? So what is the meaning of mu*cp*rho*Tf dA/Sum mu*cp*dA. I think, Sum (addition) mu(mass flow rate), cp (specific heat) rho(heat transfer cofficient outer side), Tf (fluid temp), dA(area ) but which area? cross-sectional or surface area? Kindly help |
Previous time step variable to be used in UDF | CFD-user | Fluent UDF and Scheme Programming | 18 | June 23, 2022 01:17 |
Using CFD Post for OpenFoam results | Karpfen | OpenFOAM Post-Processing | 3 | January 19, 2018 08:48 |
[OpenFOAM.org] Problem installation OpenFOAM-dev | FlyingCat | OpenFOAM Installation | 15 | December 31, 2017 11:53 |
post processing for KIVA | dirga | Main CFD Forum | 5 | April 23, 2009 10:58 |
post data | starcd_learner | Siemens | 0 | February 1, 2006 11:24 |
