Validating and verifying CFD simulations
Like Tree1Likes
  • 1 Post By piu58
Old   February 1, 2018, 22:22
Smile Validating and verifying CFD simulations
Oluwaseun Adedeji
Shawnk is on a distinguished road
I am doing a CFD simulation of a flow system in a very unusual geometry. This means, not much is understood about the hydrodynamics of the system and there is limited (if any) experimental data available to validate the CFD simulation.
Besides experimental data, what other ways can one proof that a CF result is valid? Also, if you know any, kindly suggest papers or literature you know that have done CFD simulations of not-too-common systems and have validated them with minimal experimental data but also with some more substantial proof.
Thanks
Shawnk is offline   Reply With Quote
Old   February 2, 2018, 00:31
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
AT least you may perform simulation with the same physics, but simpler geometry (for which you have reference data).
If you use the same principles in simulating your case, the deviation should be in the same range. There is always an additional problem of course, the problem with meshing complicated geometries. To overcome this, try different meshing strategies and prove, that the mesh doesn't introduce a large amount of deviation.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   February 2, 2018, 01:34
Default Validating and verifying CFD simulations
Oluwaseun Adedeji
If you use the same principles in simulating your case, the deviation should be in the same range. There is always an addition problem of course, the problem with meshing complicated geometries. To overcome this, try different meshing strategies and prove, that the mesh doesn't introduce a large amount of deviation.
Thanks for your reply. Is there a literature you would recommend ?
Old   February 2, 2018, 01:55
piu58's Avatar
Uwe Pilz
It depends on your problem which I don't know.
Well understood / measured systems are flow over a plate and past a cylinder or sphere. You find tons of literature for this. Measuring values you may obtain from the old books of Ludwig Prandtl or Hermann Schlichting.
Uwe Pilz
Old   February 2, 2018, 02:04
Violet
violethill is on a distinguished road
Can you give us a little bit more information about your geometry? And what you are trying to measure? Without a problem statement we cannot help you other than give you general suggestions which would not be much of a help. In that way, perhaps we can also help give suggestion on the experimental part.
violethill is offline   Reply With Quote
Oluwaseun Adedeji
Thanks again for your response
Old   February 2, 2018, 02:20
Oluwaseun Adedeji
A typical example is to consider the wheel of a car. Instead of it being filled with high pressure air, it is filled with both water and air in equal proportion. When the wheel rotates, what happens to the hydrodynamic of the water inside. I have already considered torque measurement and prediction. What other ways can one validate the water hydrodynamics?
Old   February 2, 2018, 02:33
piu58's Avatar
Uwe Pilz
You have a two pahse problem, air and water. For this the easiest point to start is the ascending bubble. You don't have external forces beyond gravity there, but it is the first example I would try to solve. There is an excellent report by Hysing about this.
Shawnk likes this.
Uwe Pilz
hydrodynamics, model validation
