February 14, 2018, 08:53 |
TEqn. in PorousSimpleFoam
Ramana
Rep Power: 8 |
Hi Everyone,
I am new to OpenFoam. I am doing numerical simulation of fluid flow(incompressible)and Heat transfer from a porous square cylinder placed in the middle of a channel (maintained at constant Temp. > fluid Temp.)to a flowing wind. For fluid flow(incompressible) simulation, the existing Poroussimplefoam(Darcy-Forchheimer Model) is giving fairly reasonable results on Cd and wake length. Now I need to simulate heat transfer from porous square cylinder. I found a thread on this forum where in, the procedure for adding TEqn. to icoFoam is available. In my case the flow filed is only fluid and porosity is defined as source/sink ter using "topoSet. The porous square cylinder is maintained at fixed Temp.using scalarFiXedValueConstarint in fvOptions fvOptionsDict Code:
s1 { type scalarFixedValueConstraint; active true; scalarFixedValueConstraintCoeffs { selectionMode cellZone; cellZone porousBlockage; volumeMode uniform; fieldValues { T 353; } } } Code:
TEqn:fvScalarMatrix TEqn ( //fvm::ddt(T) // <--- steady state simulation, so ddt disabled... //+ fvm::div(phi, T) - fvm::laplacian(DT, T) == fvOptions(T) // porouszone is maintained at const. temperature ); TEqn.relax(); fvOptions.constrain(TEqn); TEqn.solve(); fvOptions.correct(T); following are the flow and heat transfer parameters considered Re 40 Darcy no (Da ): 10e-2 porosity value: 0.993 Pr :0.71 I have few observations in this 1). There is no entry for porosity value as an input parameter.is it okay or am i missing something? 2). I want to calculate Nusselt Number ,i have general idea about calculation of Nusset number for solid cylinder, in my case the porous cylinder defined as source/sink (no physical surfaces/patches) 3). Is there available code for calculation Nusselt Number for porous blockage.? I have searched many threads on this forum,but no luck.It will be great if someone can help me to run this simulation Thank You, Svramana Last edited by svramana; February 19, 2018 at 01:26. |
porous boundary, porous cell zone, poroussimplefoam |
porousSimpleFoam | aban | OpenFOAM | 10 | July 20, 2022 03:01 |
How do I analyse the odd results (with porousSimpleFoam) ? | deepbandivadekar | OpenFOAM Running, Solving & CFD | 3 | January 17, 2018 05:15 |
[snappyHexMesh] Is it possible to set flow to laminar with porousSimpleFoam solver? | Caio Martins | OpenFOAM Meshing & Mesh Conversion | 3 | May 17, 2016 14:12 |
Replace H equation with Teqn in chtMultiregionFoam OF 2.3 | Moncef | OpenFOAM Running, Solving & CFD | 0 | May 22, 2014 20:37 |
porousSimpleFoam - crash | Sebaj | OpenFOAM | 2 | January 4, 2012 16:16 |
