How to do the wall boundary conditions for γ-Reθt transition model?
Old   April 14, 2018, 07:58
Unhappy How to do the wall boundary conditions for γ-Reθt transition model?
Zhao H.Y
gmreszhao is on a distinguished road
I want to use the γ-Reθt model for the prediction of hypersonic flow, but I do not know how to do the wall boundary conditions for γ and Reθt.
According to Langtry and Menter’s paper “R.B. Langtry, F. R. Menter, Correlation-based transition modeling for unstructured parallelized computational fluid dynamics codes, AIAA Journal, 2009, 47(12):2894-2906”, the boundary conditions for γ and Reθt at a wall are zero normal flux and zero flux, respectively.
I think the normal fluxes of γ and Reθt are ρVnγS and ρVnReθtS, respectively, where the ρ, Vn and S are density, normal velocity and wall area of a control volume, respectively. Because the velocity Vn is zero at the no-slip wall, ρVnγ and ρVnReθt are zero regardless of the values of γ and Reθt.
I have read a lot of papers about the transition prediction with γ-Reθt transition model. There are two methods about the boundary conditions of γ and Reθt. Some set the γ and Reθt as zero at the wall, and others set the normal gradients of γ and Reθt as zero at the wall. Which method is the better choice? Or if is any other method better?
gmreszhao is offline   Reply With Quote
γ-reθt model, boundary condition, transition, wall
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 21:16
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
