How can I create labels in HDF5 in order to convert to CGNS later?
Old   February 10, 2020, 12:30
Default How can I create labels in HDF5 in order to convert to CGNS later?
Gustavo Exel
Gustavo Exel is on a distinguished road
I'm working in a simulator within a program, and I'm not abled to use the CGNS library, however my output needs to be in the .cgns format. I'm using the HDF5 library which can generate CGNS files, but have different classes. For example, the HDF5 class Group corresponds to the CGNS class Node, thus, when HDF5 generates a CGNS file, you may use the Group class and it'll output a proper CGNS file with Nodes. However, nodes have an important feature which are the labels, and I can't find a way to generate the Nodes labeled using HDF5. Could you let me know this correspondent class or a way to do this conversion?
Gustavo Exel is offline   Reply With Quote
c++, cgns, hdf5
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 18:25
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 14:18
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
[blockMesh] Does blockMesh create mesh vertices in any particular order brooksmoses OpenFOAM Meshing & Mesh Conversion 3 December 12, 2005 20:26
