June 6, 2018, 14:36 |
1-way fsi: importing the loads
SMN
Rep Power: 16 |
In my 1-way fsi simulation, I need to import the cfx loads ".res" manually to the structural. because I have the res file on my comptuter and i do not need to solve the fluid again, so I do not want to create a link between cfx>solution to structural>setup. Is there any ways to import the loads to structural manually?
thanks |
June 7, 2018, 04:32 |
wujun
Rep Power: 14 |
you should define the boundary which added the load in the CFD model in advanced.when finished the CFD caculation,you can import the CFX loads in the FEA model,I have done a simiar work in the WORKBENCH.you can try again.
June 10, 2018, 03:49 |
Fsi
Hamidreza
Hi
I'm running a FSI in ANSYS Fluent. However, I encountered the following error. Error Description : Fluent encountered fatal error after sync point Solve:Update-Dynamic-Mesh failed. Negative cell volume detected How can I fix this problem, please? |
[DesignModeler] Importing ICEM-generated geometry into DesignModeller for 2-way FSI | user_of_cfx | ANSYS Meshing & Geometry | 0 | April 25, 2012 06:33 |
FSI - Importing load (Mapping) | moonomid | CFX | 0 | June 3, 2011 11:33 |
BCs in an FSI simulation of a flexble pipe | vivekcfd | OpenFOAM | 10 | January 8, 2010 04:14 |
fsi | sun | Siemens | 8 | January 19, 2009 23:17 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
