Home > Forums > Software User Forums > COMSOL
Modeling 2 phase mixing in T juncture
Old   June 8, 2018, 03:28
Default Modeling 2 phase mixing in T juncture
Shaheer
Shaheer is on a distinguished road
I am trying to simulate a convective mixing situation with 2 inlets introducing 2 different liquid (for practice sake I had water and ethanol). I used Level set multiphase flow option. I have tried to model it as the example of 'Droplet Breakup in a T-Junction' example in COMSOL example directory in 2 D to speed up the calculation process; so that i can work further after the first result by adding complexities however even keeping the study to solve itself for overnight nothing happens it either stays stuck or says cannot converge. What am I doing wrong? File Access link
Please advice.
Shaheer is offline   Reply With Quote
Old   August 20, 2018, 18:20
habibjalili
habibjalili1995 is on a distinguished road
Please advice.
Hi
I currently sudy on mixing in micro channel by use cunductive particle to increase the mixing quality your project is so good because of two phase modelling I think use it as microreactor is good to....So let me look at your files and i will tell you about it
habibjalili1995 is offline   Reply With Quote
comsol 5.3a, microfluid, mixing
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam xpqiu OpenFOAM Community Contributions 8 June 17, 2015 02:08
modeling of two phase flow combustion in fluidized bed with MFIX ehsan.m Main CFD Forum 0 July 17, 2013 16:47
phase change modeling Danial Q Main CFD Forum 0 April 5, 2012 01:14
Discrete Phase Modeling Fred Kang FLUENT 3 October 18, 2000 10:23
