Best open source SPH code to use?
Like Tree4Likes
  • 2 Post By beer
  • 1 Post By specializedSPH
  • 1 Post By meandcfd
Old   September 6, 2018, 04:00
Question Best open source SPH code to use?
anonymous001
bladomas is on a distinguished road
I will be modelling tube flow with the use of SPH (smoothed-particle hydrodynamics). My question was, which open source SPH code would be the best to use? Or which ones have clear advantages (some disadvantages as well) over others? I have found a website which lists several of them but I'm not sure if I can post a link here (for now).
bladomas is offline   Reply With Quote
Old   September 10, 2018, 14:20
beer is on a distinguished road
The most known and used one if probably DualSPHysics from
http://dual.sphysics.org/
I personally think that the best one right one is probably SPHlisHSPlasH
https://github.com/InteractiveComput...s/SPlisHSPlasH
They implemented almost every model I know for SPH.
elvis and 8cold8hot like this.
beer is offline   Reply With Quote
Old   September 11, 2018, 03:29
anonymous001
Thanks for your reply, I will check out SPHlisHSPlasH. After looking into some free codes, I found GPUSPH to be decent. How comparable is it to SPHlisHSPlasH?
Old   September 11, 2018, 08:12
I think I tried the GPU-Version of GPUSPH at some point. My concern was that it had only constant material properties for water and WCSPH as a solver.
I am not 100% sure though.
Old   September 11, 2018, 08:19
anonymous001
My end goal is model blood flow in arteries with moving walls. I will be starting out quite simple, normal tube flow with water. So I'm not sure whether having only constant material properties is an issue for me. I think I'm more interested in the ease of use and how easy it is to learn using the code.
Old   September 22, 2018, 07:22
Smile Sph
Dr. sadra
specializedSPH is on a distinguished road
I can send you my developed ISPH code that I wrote about 8 papers with it:
1. Incompressible SPH simulation of landslide impulse-generated water waves. Natural Hazards, 82(3), 1779-1802.
2. Modified variable mass incompressible SPH method for simulating internal fluid flows. Journal of the Brazilian Society of Mechanical Sciences and Engineering, 38(7), 2009-2027.
3. Eulerian ISPH Method for Simulating Internal Flows. Journal of Applied Fluid Mechanics, 9(3).
4. On the numerical simulation of the nonbreaking solitary waves run up on sloping beaches. Computers & Mathematics with Applications, 70(9), 2270-2281.
5. Comparative study on the accuracy of solitary wave generations in an ISPH-based numerical wave flume. Applied Ocean Research, 54, 115-136.
6. Simulating Solitary Wave Generation Using Incompressible SPH. Ann Limnol Oceanogr 1(1): 013-021.
7. On the Generation, Propagation and Runup of Solitary Water Waves on Steep Beaches, in 6th International Offshore Industries Conference (Tehran, Sharif University of Technology: 2015).
8. ISPH Numerical Simulation of Tsunami Generation by Submarine Landslides, Arabian Journal of Geosciences
p2u3nit likes this.
specializedSPH is offline   Reply With Quote
Old   September 23, 2018, 07:48
anonymous001
I would love to have a look at your code. I'm currently busy learning C++ and several different programs for compiling codes. Soon I will have a good look at the codes and compare them.
Old   September 23, 2018, 09:31
Dr. sadra
mail to futureidea@chmail.ir to send code.
Old   September 23, 2018, 18:48
Default Multiple Kernels and Flexible EOS
Peter Brady
pbrady2013 is on a distinguished road
Hi @beer,
From my recollection you were right from a while ago.
I use GPUSPH now and am getting good results. There are different kernels now and flexible equations of state.
I'm focussed on free surface problems and have not tried enclosed flows with moving walls as the OP has later added. Would be worth a look.
Cheers,
-pete
pbrady2013 is offline   Reply With Quote
Old   June 24, 2019, 15:10
meandcfd is on a distinguished road
This is not free code. specializedSPH is selling it. His/her comment via email when asked about it being free: "And you figured it would be free of charge? Extraordinary Impression!!!!!!!!!!"
Ayioyou likes this.
meandcfd is offline   Reply With Quote
Old   June 26, 2019, 07:55
Originally Posted by pbrady2013 View Post
Hi @beer,
Cheers,
-pete
Hi Pete
So they added a few features, nice. Especiall the moving and floating objects seem to perform well.
However they still only have WCSPH implemented. You should have a look at PCISPH and IISPH. Those are iterative methods for incompressible SPH but do not need the solution of a PPE. The possible speed up is crazy and the incompressbility is acutally enforced. Those are implemented in SPHlisHSPlasH.
I haven't had a look into these codes lately because I decided to write my own OpenCL code (don't do that...) and now Cuda code (much better).
Regards
Old   June 26, 2019, 09:44
If the problem is dealing with incompressible then look at MPS (moving particle semi-implicit) which has been around for years and addresses incompressible.
Old   June 26, 2019, 19:00
Default Thanks for the Tip
  #13
Peter Brady
Hi Pete
Regards
Hey @beer,
Thanks for the clarification and update. I should have a look at your code. Its that the following link on github?
GPUSPH released an updated solver yesterday but still WCSPH.
Cheers,
-pete
Old   June 27, 2019, 03:39
Oh, it is not my code. I have a differnt one with different features. I just think it is really cool.
Old   August 18, 2019, 02:39
hancock is on a distinguished road
For mesh free methods PySPH is an opensource tool which provides a wide range of schemes for simulating the various type of physics. and the good part about it is that a python code is used to change or create a new scheme or simulation. The link for the software is
https://github.com/pypr/pysph
hancock is offline   Reply With Quote
Old   September 7, 2021, 06:02
Alexander Kazantcev
AlexKaz is on a distinguished road
Free DualSPHysics, I think. It works on cuda cards and CPUs. In my tests Ryzen 1800x (~160-180 GFlops in double) was about 3 times slower than NVIDIA Tesla C2050 (~500 GFlops in double).
https://dual.sphysics.org/downloads/
AlexKaz is offline   Reply With Quote
sph method
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 04:01
[waves2Foam] Tripping over several build issues with OpenFOAM 2.1.1 Yage OpenFOAM Community Contributions 18 February 15, 2016 02:02
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
