Minimizing computational complexity of large-scale airflow simulation. |
October 20, 2018, 14:27 |
John Tristan Ritland
Hi, I am extremely new to CFD, and am considering using openFOAM to create a basic climate model that can be used to proceduraly generate worlds for games and such.
One of the largest difficulties that I can see is minimizing the computational requirements to the point that the system can make a prediction that "looks good enough" (e.g. models temperature, evaporation, and rainfall, while at least considering the effects of atmospheric circulation currents and terrain ) within a few minutes of compute time on consumer grade hardware. With these restrictive computational constraints in mind, can one model convection over a flat, horizontal plane with a temperature differential, and flow obstructions without simulating a "full" third dimension? I'm wondering if you couldn't have basically three two-dimensional "layers", simulating air-flow near ground level, air-flow at high altitude, and a intermediary to simulate gas exchange between the two. If there's been work on this already, even just a research paper to start from, I could use it, but I really don't have the expertise right now to implement this from scratch myself. Secondly, modeling flow restrictions caused by terrain "properly" would require expensive precision. mountains might only be a mile or two tall, with Everest being 5.5ish, while the thickness of the atmosphere worth modeling could be as much as 10 miles. half-mile precision, by using twenty layers of atmospheric cells would be computationally expensive. Is there a cheaper way to simulate flow obstruction, and the forced rising of air caused by mountains and high terrain? Finaly, what am I missing? Is there a forum for climate modeling that I don't know exists that might be helpful? is there a computationally cheap library for this exact sort of thing already around? Other general recommendations that you wish you knew when you started learning CFD? |
Modelled Length Scale in SAS-SST Simulation | jego | Main CFD Forum | 0 | January 16, 2016 06:45 |
Smallest length scale in Large eddy simulation | maphd | Main CFD Forum | 12 | August 8, 2015 13:04 |
large eddy simulation | 7sunnyshikhar | Main CFD Forum | 1 | July 14, 2013 08:09 |
Large Eddy simulation | Andreas Hauser | Main CFD Forum | 1 | May 20, 2000 20:33 |
Computational complexity of Navier Stokes equations | Marco Ellero | Main CFD Forum | 5 | May 5, 1999 21:07 |
