October 24, 2018, 03:42 |
Wire coil inserts
Madhu Sruthi Emani
Can I get some help to mesh pipe flow with wire coil inserts in wall attached position. I need some rough idea to start with. I've been reading so much yet I'm not clear how to mesh with limited elements. The automatic mesh gave me about 80 lakh elements.
October 26, 2018, 10:30 |
Lee Strobel
Rep Power: 10 |
Hi Madsam, it might help if you could provide an image or sketch of the geometry you have. Also, you should clarify what meshing software you are trying to use.
[ANSYS Meshing] mesh of pipe which inserted a wire coil in this pipe | tuna | ANSYS Meshing & Geometry | 7 | November 7, 2015 01:48 |
Cooling coil simulation in room | hanqiang | Phoenics | 1 | September 23, 2014 09:52 |
[ANSYS Meshing] Is somewhat missing in Heating Coil mesh tutorial? | pavilion | ANSYS Meshing & Geometry | 0 | April 6, 2012 05:02 |
Spiral coil heat exchange | luznyr | FLUENT | 0 | August 11, 2011 23:57 |
[Other] Mesh generation method for coil heated within shell | Asghari_M | ANSYS Meshing & Geometry | 0 | June 8, 2011 08:03 |
