Modeling Aluminum Combustion
Old   November 20, 2018, 16:31
Default Modeling Aluminum Combustion
Swagnik Guhathakurta
Swagnik is on a distinguished road
Hello Everyone,
I am trying to implement Aluminum particle combustion according to the model by Hayashi (https://arc.aiaa.org/doi/pdf/10.2514/1.20412). I am only interested in the source terms, since the hyperbolic terms are already accounted for in my code. I am particularly interested in the source terms due to phase change. In their first equation, the species mass conservation equation source term, they have an m_dot which they call delta_c, plus an omega_dot term, where the omega_dot represents source terms due to homogeneous chemical reactions. They assume infinitely fast reactions. Does that mean that the omega_dot is zero for all species? If yes, can you please explain why? Also, for the delta_c part of the equation, they have a term xi_k as coefficient, and they say that xi_k is = 1 for aluminum and 0 for everything else. If so, then how do the reactions affect the production or destruction of species in the source term for all other species (if omega_dot is also zero then the entire source term for all other species would be zero)?
I would really appreciate if anyone can help me with this. If you do not have access to the paper, please let me know and I can probably Email it to you or upload it on dropbox or something.
Regards,
Swagnik
Swagnik is offline   Reply With Quote
Problem with Finite Rate in Combustion Modeling mengke FLUENT 1 March 8, 2021 14:09
Where to start using CFD combustion modeling? urbansound Main CFD Forum 2 November 2, 2018 08:13
Eddy dissipation concept for turbulent combustion modeling sahmed OpenFOAM Running, Solving & CFD 3 July 21, 2017 10:45
Combustion Modeling in internal combustion engine Joeyt FLUENT 3 May 26, 2013 05:30
combustion modeling in CFX info_bahaider CFX 1 August 23, 2009 08:28
