Transfer output data as input for second calculation
Old   June 2, 2010, 03:16
Default Transfer output data as input for second calculation
mannobot is on a distinguished road
Hi there,
I need to know wether or not it is possible to transfer the the output from one calculation as input for another calculation. I do use FLUENT. I know that I am able to transfer data within the same calculation between two not connected surfaces. But I want to start a calculation, e.g. calculate a channel flow and transfer the velocity profile at the outlet to a second calculation and use it as an velocity inlet boco. Is that possible using FLUENT.
Any help would be much appreciated.
Sincerely
Mannobot
mannobot is offline   Reply With Quote
Old   June 2, 2010, 03:55
got it.
Thanks
Old   December 7, 2018, 06:51
Mostafa
sasa mohamed is on a distinguished road
Hi mannobot, Can u show me the steps to do this process?
thanks in advance
sasa mohamed is offline   Reply With Quote
Old   December 7, 2018, 09:37
Lucky
Write a BOUNDARY PROFILE and then read it into the next case.
There's 2+ tutorials in the Fluent manual. Press F1.
OpenFoam vs CFX5 mass balance in OpenFoam tangd OpenFOAM Running, Solving & CFD 33 May 23, 2010 16:36
best mesh generator for conjugate heat transfer? phsieh2005 Main CFD Forum 1 June 1, 2007 17:35
Numberical Solution of Parabolic PDE(heat transfe) M Ahmed Main CFD Forum 0 March 11, 2007 06:50
Help regarding cgns for Conjugate heat transfer Aditya Main CFD Forum 1 December 7, 2006 08:13
Need help for Gambit/Fluent/ANSYS data transfering S-Y. Chen FLUENT 2 April 30, 2003 05:08
