Transfer output data as input for second calculation |
June 2, 2010, 03:16 |
Rep Power: 16 |
Hi there,
I need to know wether or not it is possible to transfer the the output from one calculation as input for another calculation. I do use FLUENT. I know that I am able to transfer data within the same calculation between two not connected surfaces. But I want to start a calculation, e.g. calculate a channel flow and transfer the velocity profile at the outlet to a second calculation and use it as an velocity inlet boco. Is that possible using FLUENT. Any help would be much appreciated. Sincerely Mannobot |
June 2, 2010, 03:55 |
Rep Power: 16 |
got it.
Thanks |
December 7, 2018, 06:51 |
Mostafa
Rep Power: 11 |
Hi mannobot, Can u show me the steps to do this process?
thanks in advance |
December 7, 2018, 09:37 |
Lucky
Rep Power: 66 |
Write a BOUNDARY PROFILE and then read it into the next case.
There's 2+ tutorials in the Fluent manual. Press F1. |
OpenFoam vs CFX5 mass balance in OpenFoam | tangd | OpenFOAM Running, Solving & CFD | 33 | May 23, 2010 16:36 |
best mesh generator for conjugate heat transfer? | phsieh2005 | Main CFD Forum | 1 | June 1, 2007 17:35 |
Numberical Solution of Parabolic PDE(heat transfe) | M Ahmed | Main CFD Forum | 0 | March 11, 2007 06:50 |
Help regarding cgns for Conjugate heat transfer | Aditya | Main CFD Forum | 1 | December 7, 2006 08:13 |
Need help for Gambit/Fluent/ANSYS data transfering | S-Y. Chen | FLUENT | 2 | April 30, 2003 05:08 |
