Check cases for turbulance heat transfer on a complex shape
Old   May 31, 2000, 09:45
Default Check cases for turbulance heat transfer on a complex shape
Mehdi
Dear Sir I am working on turbolent heat transfer problems by finite volume method and try to write a code as general as possible for a special case. to see wether my code works well or not I need some test cases for turbulent heat transfer phenomena on a complex shape. but unfortunately the present codes I know are only for simple cases.that would be very kind of you to introduce me some... Yours Faithfully abedi
Old   June 1, 2000, 04:56
Default Re: Check cases for turbulance heat transfer on a complex shape
mehrdad
Dear Mehdi,
Can you explain more about the flow geometry.
In order to get a nice temp. field, you must resolve the flow and turbulence fields (specially near the wall) very well. So before looking at heat transfer I think you should make some comparisons for flow.
Old   June 1, 2000, 07:58
Mehdi
Dear Sir I have solved the flow over any complex shape for my special case and I am sure that the flow field soloution works well.but as you know in finite volume method there are source terms which depends on grid generation over field .for this reason when i am going to solve the energy equations over this field I have to check the solution for insurance,not only for the simple cases which their meshes are some how uniform or in a good conditions but also for complex shapes which have nonuniform meshes to check wether source terms are good or not
thanks for your attentions M. Abedi
Old   June 1, 2000, 22:36
John C. Chien
(1). In turbomachinery, the cavity flow heat transfer is always an important problem. There, the cavity geometry is not always a rectangular cavity. (2). Try to look into the ASME/Journal of Turbomachinery, in the area of cavity flow heat transfer. (3). There is also a more important heat transfer problem, that is the HP turbine blade heat transfer with internal cooling. I am sure that you will be able to find something in this area too.
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 21:41
Fluid/Object Heat Transfer jfasl FLOW-3D 1 April 5, 2011 00:33
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
need papers on heat transfer George Main CFD Forum 0 November 27, 2008 07:42
heat transfer in two-phase flow Leonid Fromzel CFX 0 April 8, 2008 05:57
